 Post subject: Seagate Rosewood Digital Signature Verification failure
PostPosted: May 1st, 2023, 12:51
Can someone provide a solution for Seagate 2TB Mobile ST2000LM007 PN:1R8174-570 FW:EB01 Site:TK FW:EB01 DOM:21NOV2022 PCB:100835923 REVB
Drive comes to ready with full ID but none of the sectors are accessible.
ROM is NOT readable through the terminal. I wrote unlock patched to the ROM externally and yet I can't send the UNLOCK signal through the PC-3000 terminal to the drive.
I used an exact matching DONOR pcb with transferred patient's ROM but I get this error message:
Flash boot code Digital Signature Verification failure! :(
and the drive doesn't even turn on.
Here is my question, is there a way to change the Digital Signature of the patient's ROM to make it compatible with DONOR pcb controller's Digital Signature?
Thank You!
ST2000LM007_EB01_ROM.zip [498.64 KiB]
Downloaded 404 times
 Post subject: Re: Seagate Rosewood Digital Signature Verification failure
PostPosted: May 2nd, 2023, 3:29
Could we see the donor's ROM?
If the code sections are identical, apart from the signatures, then perhaps you only need to transfer the adaptives???
PostPosted: May 2nd, 2023, 9:50
Hello Fzabkar,
Yes, I attached the donor's ROM for comparison.
But Transferring the adaptives does't work since it causes the same error message and drive won't even turn on.
Thank You!
ST2000LM007_EB01_DONOR.zip [492.17 KiB]
Downloaded 336 times
PostPosted: May 2nd, 2023, 14:02
Here is a similar thread where at least some of the digital signatures have been identified:
https://forum.hddguru.com/viewtopic.php?f=1&t=42905
ISTM that the adaptives must be included in the signature verification. I wasn't expecting that.
I have extracted these SMART reports from your patient ROM. It shows a rapid degradation in the space of 37 hours.
ID  Flg  Cur  Wor  Raw             Description
  1  0F    49   49  00093C0C65CD12  Raw Read Error Rate
  3  03   100  100  00000000000000  Spin Up Time
  4  32    93   93  00000000001F98  Start/Stop Count
  5  33    99   99  000000000001CA  Reallocated Sector Count
  7  0F    69   60  00000000778BB4  Seek Error Rate
  9  32    98   98  091DC300000711  Power-On Hours Count
10  13   100  100  00000000000000  Spin Retry Count
12  32   100  100  00000000000013  Drive Power Cycle Count
184  32   100  100  00000000000000  End to End Error Det/Corr Count
187  32     1    1  000000000008D1  Reported Uncorrectable Errors
188  32   100   99  00000200020002  Command Time Out
189  3A   100  100  00000000000000  High Fly Writes
190  22    71   50  000000231B001D  Airflow Temperature
191  32   100  100  00000000000001  Shock Sense
192  32   100  100  01000000000003  Emergency Retract Cycle Count
193  32    81   81  0000000000965D  Load/Unload Cycle Count
194  22    29   50  0000120000001D  HDA Temperature
197  12   100  100  00000000000020  Current Pending Sector Count
198  10   100  100  00000000000020  Offline Uncorrectable Sector Count
199  3E   200  200  00000000000000  UltraDMA CRC Error Rate
240  00   100  253  2F769600000127  Head Flying Hours
241  00   100  253  000000903BDEB2  Total LBAs written
242  00   100  253  000000BC514F1D  Total LBAs read
254  32   100  100  00000000000000  Free Fall Sensor
  1  0F    46   45  00032401C10B10  Raw Read Error Rate
  4  32    93   93  00000000001FB0  Start/Stop Count
  5  33    89   89  00000000001310  Reallocated Sector Count
  7  0F    69   60  000000007A0FCD  Seek Error Rate
  9  32    98   98  12CD6100000736  Power-On Hours Count
12  32   100  100  00000000000014  Drive Power Cycle Count
184  32     1    1  00000000000068  End to End Error Det/Corr Count
187  32     1    1  00000000001677  Reported Uncorrectable Errors
188  32   100   86  000009000B0019  Command Time Out
190  22    61   50  0000002A200027  Airflow Temperature
193  32    81   81  0000000000975D  Load/Unload Cycle Count
194  22    39   50  00001200000027  HDA Temperature
197  12    98   98  000000000000B0  Current Pending Sector Count
198  10    98   98  000000000000B0  Offline Uncorrectable Sector Count
199  3E   200  196  00000000000068  UltraDMA CRC Error Rate
240  00   100  253  34861B0000012D  Head Flying Hours
241  00   100  253  000000905FECF3  Total LBAs written
242  00   100  253  000000C015CABE  Total LBAs read
PostPosted: May 4th, 2023, 14:14
Thank you Fzabkar for your reply, looks like this case is not recoverable at least now.
PostPosted: May 4th, 2023, 20:48
We have a solution if you want to outsource.
PostPosted: May 6th, 2023, 3:47
bonjour,
même problème,
j'ai laissé le disque toute la nuit branché sur mon pc et le matin sur mon vieux pc3000 et il tourne, lentement mais il tourne, j'ai accès aux datas, et j'ai pu cloner le disque.
peut-être est ce un miracle mais vous pouvez tenter.
Good morning,
same problem,
I left the disk all night plugged into my pc and in the morning on my old pc3000 and it spins, slowly but it spins, I have access to the data, and I was able to clone the disk.
maybe it's a miracle but you can try.
Users browsing this forum: No registered users and 116 guests
