| FW Request:WD2500AAJS-22VWA0 http://forum.hddguru.com/viewtopic.php?f=11&t=43521 |
Page 1 of 1 |
| Author: | Zero Alpha [ July 27th, 2023, 21:50 ] |
| Post subject: | FW Request:WD2500AAJS-22VWA0 |
Does anybody have firmware for WD2500AAJS-22VWA0 please |
| Author: | digisupport [ July 29th, 2023, 4:14 ] |
| Post subject: | Re: FW Request:WD2500AAJS-22VWA0 |
What version do you need ? There are 6 firmwares in the files section here.. |
| Author: | Zero Alpha [ July 29th, 2023, 19:46 ] |
I need 005800A3 not in files section |
| Author: | unknown [ July 30th, 2023, 10:43 ] |
https://firmware.hddsurgery.com/index.p ... rnado%202D |
| Author: | Zero Alpha [ July 30th, 2023, 19:17 ] |
unknown wrote: https://firmware.hddsurgery.com/index.php?manufacturer=Western%20Digital&family=Tornado%202D |
| Author: | Zero Alpha [ August 29th, 2023, 0:51 ] |
I finally got the firmware for this and solved the case! The head map probably stopped other versions from working. I'll leave this here for anybody with a similar case. PM for firmware. Family:................................. : Tornado 2D Techno mode key......................... : Ok HDD Status sector....................... : Ok RAM: System controller (SoC)................. : 88i6745B1 0x(42B1) HDD Info reading........................ : Ok Heads number............................ : 3 Cyl Count............................... : 128 ROM: Read ROM................................ : Ok ROM Data size........................... : 192 Kb Flash ROM dir reading................... : Ok SA regions address...................... : by default SA regions address (RAM)................ : by default Module 02 access........................ : Granted SA SPT.................................. : 857 SA Translator loading................... : Ok SA defects assigned..................... : 1 Reading by ABA may get wrong data ROM Modules: ROM version............................. : 58.A3D Module 4F F/W version................... : 005800A3 Overlay F/W version..................... : 58.A3D Servo F/W version....................... : 01.0L Heads configuration..................... : by map Heads number............................ : 4 Heads number in use..................... : 3 Switched off heads...................... : Yes Heads map............................... : 1,2,3 Relocations............................. : 0 (1 465) Read ROM DCM............................ : Ok Power up log reading.................... : Ok Power up load dir data.................. : Yes Power up load permovl................... : Yes Power up load CFG data.................. : Yes |
