| Scan and Index a large MFT http://forum.hddguru.com/viewtopic.php?f=11&t=43543 |
Page 1 of 1 |
| Author: | Eastcoast [ August 9th, 2023, 10:51 ] |
| Post subject: | Scan and Index a large MFT |
Got a 8TB Seagate in - obviously been suffering for a long time with the number of FOUND folders. Question is, NTFS MFT is 14GB in size. Managed to get a good read, but now waiting an age for it to scan and index. Over 15million file entries. Is there a quicker way? 5 hours in, it's 70% scanned in DE. Have powered the drive down in the meantime, so running it in DATA copy mode. If I known it would take so long I should have started the task on an SSD and then moved it to a drive. |
| Author: | Arch Stanton [ August 10th, 2023, 17:23 ] |
| Post subject: | Re: Scan and Index a large MFT |
I suppose it finished by now |
| Author: | Lardman [ August 11th, 2023, 4:13 ] |
Eastcoast wrote: Is there a quicker way? 5 hours in, it's 70% scanned in DE. Did you check task manager to see where the load was ? I can't say I've noticed excessive delays but then I don't work from a single spinner and the machine is maxed on ram.
| Author: | Eastcoast [ August 11th, 2023, 8:01 ] |
Arch Stanton wrote: I suppose it finished by now Took 30 hours. Might be time to increase RAM. I thought 16GB was enough |
| Author: | Eastcoast [ August 11th, 2023, 8:06 ] |
Lardman wrote: Eastcoast wrote: Is there a quicker way? 5 hours in, it's 70% scanned in DE. Did you check task manager to see where the load was ? I can't say I've noticed excessive delays but then I don't work from a single spinner and the machine is maxed on ram.Yes, I did find a Ram hog from an old program that I no longer use running a search service that was frequently up to 6GB. I've since uninstalled it and I think it should help things. Run main system of NVME drive but the job task was on a regular HDD, so it may be bottlenecking. Might be time to swap out some of my older drives to be fair. |
