seagate hepburn smp issue
http://forum.hddguru.com/viewtopic.php?f=11&t=43752
Author:  higgsboson [ October 17th, 2023, 0:08 ]
Post subject:  seagate hepburn smp issue
I am stuck up on sysfile 93 as its not getting modified.What could be the issue
Author:  northwind [ October 17th, 2023, 3:54 ]
Post subject:  Re: seagate hepburn smp issue
Your heads can't write.
Open a non-important sysfile or module and modify a few bytes, try to write them to drive. If it fails -- you have your answer.
If it succeeds, then there is problem to SA area where 93 is located. Fixing 93 is not a big deal, but see if your heads can write first.
You can also try and edit 93 in RAM -- no need to write to SA.
Author:  higgsboson [ October 17th, 2023, 23:40 ]
Yes northwind O can't write anything ,heads are damaged. Thanks for pointing out
Author:  northwind [ October 18th, 2023, 5:09 ]
You can probably still get data if heads can read but not write, but it's always best change to them.
Author:  Rudra [ October 19th, 2023, 6:00 ]
This case does not needs head transplant & can be easily solved by shorting read channels in flat 2 min.
higgsboson something is wrong in your timings. You will have to be quick to press control+Z .
Author:  northwind [ October 19th, 2023, 6:10 ]
actually, he doesn't even have to short read channel.
