 Post subject: Pharaoh oasis not giving sector access
PostPosted: October 23rd, 2023, 10:57
This Seagate pharaoh _Oasis ST 1000DM10 /CC46 is certified refurbished & is getting busy continuously .When Initially powered while entering utility it gives short error for a moment . Though I have been able to read rom it has not getting written with ROM.bin name but with its serial no also (ROM_ZN1TQ7XV_D6132ED5). Unfortunately I don't have donor pcb 100849237 Rev B (I have 230 Rev A)
Is this PCB related issue or something is wrong in rom? I get sector access but disk becomes busy every now & then.I can't create headmap as well.Whenever any command is issued disk becomes busy.
Here are terminal outputs and rom image as well.
rom - https://drive.google.com/file/d/1-zq6gG ... sp=sharing
arsing multipart flash image....... Flash ROM image
Part 1...
Parsing container segment....... Flash ROM part 1
WARNING! Segment header check sum is invalid!
Segment: GLOB_FLASH_DIR
Parsing segment....... GLOB_FLASH_DIR
End parsing segment... GLOB_FLASH_DIR
Segment: BOOTFW_CONT_0
Parsing container segment....... BOOTFW_CONT_0
Segment: BOOTFW_DIR
Parsing segment....... BOOTFW_DIR
End parsing segment... BOOTFW_DIR
Segment: GENERAL_DATA
Parsing segment....... GENERAL_DATA
End parsing segment... GENERAL_DATA
Segment: IAP
Parsing segment....... IAP
End parsing segment... IAP
Segment: BOOTFW
Segment: SFW
Parsing segment....... SFW
End parsing segment... SFW
Segment: SHELL
Parsing segment....... SHELL
End parsing segment... SHELL
End parsing container segment... BOOTFW_CONT_0
Segment: SAP
Parsing segment....... SAP
End parsing segment... SAP
Segment: UDS_BFW
Parsing segment....... UDS_BFW
Segment: BOOTFW_CONT_1
Parsing container segment....... BOOTFW_CONT_1
Segment: BOOTFW_DIR
Segment: IAP
Segment: BOOTFW
Segment: SFW
Segment: SHELL
End parsing container segment... BOOTFW_CONT_1
Segment: RAP
Parsing segment....... RAP
End parsing segment... RAP
Segment: BOOTFLOADER
Parsing segment....... BOOTFLOADER
End parsing segment... BOOTFLOADER
Segment: CAP
Parsing segment....... CAP
End parsing segment... CAP
End parsing container segment... Flash ROM part 1
Part 2...
Parsing container segment....... Flash ROM part 2
End parsing container segment... Flash ROM part 2
FLASH ROM bank: 0...
FLASH ROM Info
Image size............... : 524288
QNR Revisions:
Flash ROM part 1......... : 1
GLOB_FLASH_DIR........... : 1
BOOTFW_CONT_0............ : 0
GLOB_FLASH_DIR........... : 0
BOOTFW_CONT_1............ : 0
CAP
Validation Key........... : 0x00000020
Fam ID................... : 0x94 (Pharaoh_Oasis)
Fam Member............... : 0x6
Head count............... : 2
Date (ERROR!)............ : 49 - 22 -
SN....................... : ZN1TQ7XV
PCB SN................... : 0000M219DL5S
PCB PN................... : 100849238
WWN...................... : 5000C500E36FA77C
MDL1..................... : ST1000DM010-2EP102
MDL2..................... : ST1000DM010
Capacity................. : 1953525168
RAP
Format revision.......... : 0x0005
Contents revision........ : 0x0B010000
Number Sys Zones......... : 1
Number User Zones........ : 60
Heads count.............. : 2
FW Implementation Key.... : 0x16
SAP
Addr 0................... : 0x00013C00
Addr 1................... : 0x40002000
Fam ID................... : 0x94, (Pharaoh_Oasis)
Fam Member............... : 0x1
Servo FW rev code........ : 0xB42A
Max head................. : 1
Seek mode................ : 2020
Flags.................... : 1A09
Head vendor.............. : default
RRO mode................. : 0005
Preamp type.............. : 04B0
Heads polarity........... : 00 00
Logical head map......... : 00 01
Phys head maps........... : 00 01
: 00 01
: 00 01
IAP
ID, code................................ : 0xFFFF
PUIS.................................... : OFF
Active config........................... : FFFFFFFF
NAND ROM cache flag, Kahuna like........ : FFFFFFFF
NAND ROM cache flag, Rosewood like...... : FFFFFFFF
IAP 1
CODE info
Bank 0
ProdType................. : PAA5010.CCD4
Controller FW Rev........ : 03221617
Customer Release......... : CC46
Changelist............... : 01655363
Build date / time........ : 3/22/2019 4:17:15 PM
Package Global ID........ : 00699153
Package Builder ID....... :
Build Rev................ :
Package Rev.............. : PH031C
Pkg P/N.................. : 100851706
Servo FW................. : B423 / ---- / ---- / ----
Package Version.......... : PAA5010.CCD4.PH031C.CC46
Pkg CFW Ver.............. : PAA5010.CCD4.01655363.00699153
Bank 1
ProdType................. : PAA4010.BRNB
Controller FW Rev........ : 12011339
Customer Release......... : ZZZZ
Changelist............... : 00969095
Build date / time........ : 12/1/2015 1:39:33 PM
Package Global ID........ : 00496476
Package Rev.............. : PH021C
Pkg P/N.................. : ---------
Servo FW................. : ZZZZ / ---- / ---- / ----
Package Version.......... : PAA4010.BRNB.PH021C.ZZZZ
Pkg CFW Ver.............. : PAA4010.BRNB.00969095.00496476
FLASH ROM bank: 1...
Servo-Symbol table is not found!
FLASH ROM Info
QNR Revisions:
Flash ROM part 2......... : 48
CAP
RAP
SAP
CODE info
 Post subject: Re: Pharaoh oasis not giving sector access
PostPosted: October 24th, 2023, 7:34
To begin with arrange compatible donor pcb and write rom and check disk behaviour .If same symtoms persists then rom is to blame.
PostPosted: October 24th, 2023, 23:32
I cant access any system files & Now I am getting message dignostics port locked.
I think something is wrong in rom.
PostPosted: October 25th, 2023, 3:09
Are you sure you read ROM correct ?
You have warning in log that soft cant control COM port levels.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 25th, 2023, 4:23
Hi digisupport
I have recently brought new usb 3.0 terminal adapter as original ace usb2.0 was giving errors ,but still this error has remained.
I have been able to read rom correctly despite error. Only for this case I am unable to read rom properly (may be issue is in rom itself)
Thanks.
PostPosted: October 25th, 2023, 8:35
Update to case -
One of community member has remotely checked & have corrected and patched rom in flat 2 min. Many thanks
Now drive stays busy & when after unlock handshake , it gives ID & access momentarily before going to busy state again.
What could be the reason ?
here is video showing what is happening -
https://youtu.be/6Z21g6xRC2I
PostPosted: October 26th, 2023, 5:21
terminator2 wrote:
Update to case -
Well done
I still strongly suggest to arrange donor pcb & your case will be solved.
PostPosted: October 26th, 2023, 10:44
With the timely help of digisupport this case is closed successfully .There was no issue with rom ,pcb etc.
digisupport has perfectly identified exact technical issue which was fixed in less than 1 min.
Thanks a ton digisupport. :beer: :good: :-D
Users browsing this forum: No registered users and 97 guests
