SOS help needed WD DrgnFly1 ROM regenertion
http://forum.hddguru.com/viewtopic.php?f=11&t=43797
Author:  MISU [ November 1st, 2023, 13:59 ]
Post subject:  SOS help needed WD DrgnFly1 ROM regenertion
Hello community
With ref. to my earlier post in hddoracle , I am seeking help from hddguru community
WD Green 5000AVVS AV-GP (WD5000AVVS- 63M8B0) S/N WCAVXXX hard disk is I am working with. Its motor controller ic is burnt.
This model (DragnFly1) is having embedded rom .
I was not having exact pcb (2060-701640-001 Rev. A) so I tried 2060-771640-003 Rev A from WD 10EARS 1TB hard disk.
At that time disk got detected as 250GB (from rom). I tried to apply few loaders (DragnFly2 & others) but couldn't succeed due to lack of knowledge.
I have outsourced this case to another company. They are working & have updated that case is complex and might take time.
I would like to know what could be the solution for this case. Desoldering & reading patient mcu will need lots of skill and again is not easy.
Any hint or suggestion might lead to success. Pls. help.
Thank you
Author:  pclab [ November 2nd, 2023, 3:59 ]
Post subject:  Re: SOS help needed WD DrgnFly1 ROM regenertion
Maybe I'm wrong, but if I remember this correctly, ROM should be able to be read even with motor controller burned.
If not, ACElab have several tutorial on how to recover ROM like this one: https://blog.acelab.eu.com/pc-3000-hdd- ... -mode.html
Author:  MISU [ November 2nd, 2023, 9:06 ]
Thanks pclab
I have visited this blog and have found many useful articles . I have not powered original patient board ,but will check if I could read rom .
Author:  fzabkar [ November 2nd, 2023, 12:51 ]
pclab wrote:
Maybe I'm wrong, but if I remember this correctly, ROM should be able to be read even with motor controller burned.l
The motor controller generates the Vcore and Vio supplies for the MCU. If the 5V side of the chip is damaged, then no VCore or Vio, so no MCU, ergo no ROM. If you are smart, you could patch external supplies into the Vcore and Vio test points, but then you would need to ensure that POK was active, otherwise the MCU would be stuck in the reset state.
This is the OP's PCB:
https://www.hddoracle.com/download/file.php?id=10234&mode=view
In this case Vcore and Vio would be absent.
Author:  michael chiklis [ November 2nd, 2023, 18:32 ]
I would try to fix the pcb by replacing motor ic.
If you see burnt tracks and pads, you can rebuild them with solder lugs
https://aliexpress.com/item/1005004746483452.html
Author:  MISU [ November 3rd, 2023, 2:44 ]
What a thorough technical explanation fzabkar you know inn things :good: :-D
Thank you so much
Author:  MISU [ November 3rd, 2023, 2:46 ]
Hi michael
yes if everything else failed then possibly that is the only option left.
thanks
Author:  pclab [ November 3rd, 2023, 3:54 ]
Understood. Thanks Fzabkar.
Author:  MISU [ November 4th, 2023, 0:07 ]
You are true genius fzabkar .Thanks for the indepth details. :good: :-D
Author:  MISU [ May 4th, 2024, 7:57 ]
This case is unsolved yet as many DR companies have failed , ACE is also not able to solve .Anyone wants to give it a try before I return disk
Anyway customer is also not keen on data so I will not get any money & in turn will be able to give.
Its only a technical challenge who want to take there skills
Author:  fzabkar [ May 4th, 2024, 16:53 ]
Did any of the DR companies swap or test the heads? There is always a risk of preamp damage when the drive has been overvolted on the 5V side.
Author:  MISU [ May 5th, 2024, 6:19 ]
Thank you fzabkar
No they tried to match different pCB's and tried to regenerate ROM ,they suspected head issue but since rom native rom itself was not present they did not changed heads.
Author:  fzabkar [ May 5th, 2024, 14:27 ]
You can measure the resistance between ground and each of the preamp supply pins. Do this with the PCB on and off the drive. This will tell you if the preamp is damaged.
Author:  MISU [ May 5th, 2024, 20:07 ]
Good Morning fzabkar
I don't have words for gratitude , a big Thank you
I will check & revert.
Author:  northwind [ May 8th, 2024, 3:12 ]
What is so difficult about this case that has caused 'many DR companies' to fail?
It's called hotswap.
Author:  MISU [ May 8th, 2024, 3:37 ]
ROM is embedded inside MCU , and hot swap is not supported or working for this model they said.
Author:  pepe [ May 8th, 2024, 4:09 ]
well, it should not be that difficult, idk what they were talking about... either hotswap or ldr should give sa access pretty easily.
If not, there is other problem, like preamp or even data erasure due to damaged preamp, but as i read, head swap wasn't even tried...
I would surely evaluate this option and check the head signal if SA is still not accessible. Plus i have a few other things to try if there is data erasure as mentioned.
Author:  northwind [ May 8th, 2024, 5:02 ]
This is probably the most ridiculous thing I've read in a very long time.
Author:  MISU [ May 8th, 2024, 23:22 ]
Oh its strange , they are well reputed having all gizmos and big business ,why can't they solve this simple case even with the help of ace support.
