I got this 4TB WD drive in USB enclosure Too many bad sectors made it almost impossible to read in USB mode So i Soldered SATA cable instead - Unlock ROM and WROTE it back to original PCB through POGO PINS - Drive Comes Fully Ready
- However after Decrypting the data table wont show up in DE - Through Sector Edit. Sectors before decryption was readable. After decryption is not readable - Got error messages when Building Heads map
Can anyone help me with this??? - I have tried Block Module 30 and Upload back to ROM - Block and shift SA
Model : WDC WD40NDZW-11A8JS1 Serial : WD-WXQ2E60CUVW1 Firmware : 01.01A01 Capacity : 4 TB (7 813 971 632)
Quote: Family:................................. : SpyGlass2 Ultra 2.5" Techno mode key......................... : Ok HDD Status sector....................... : Ok RAM: System controller (SoC)................. : 88i1054A1 0x(5471) HDD Info reading........................ : Ok Heads number............................ : 10 Cyl Count............................... : 384 ROM: Read ROM................................ : Ok ROM Data size........................... : 512 Kb Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 801 050 SA regions address...................... : by default SA regions address (RAM)................ : by default Module 02 access........................ : Granted SA SPT.................................. : 2136 SA Translator loading................... : Ok SA defects assigned..................... : 17 ROM Modules: ROM version............................. : 00.0AA Module 4F F/W version................... : 0000000A Overlay F/W version..................... : 00.0BA Servo F/W version....................... : 03.7B Heads configuration..................... : by map Heads number............................ : 10 Heads number in use..................... : 10 Switched off heads...................... : No Heads map............................... : 0,1,2,3,4,5,6,7,8,9 Relocations............................. : 0 (2 459) Read ROM DCM............................ : Ok Power up log reading.................... : Ok Power up load dir data.................. : Yes Power up load permovl................... : Yes Power up load CFG data.................. : Yes Service area: SA dir reading (ID)..................... : Ok Dir items loaded........................ : 644 SA Access............................... : Copy 0,Copy 1 Configuration reading................... : Ok CFG tech mode lock...................... : No Self encryption drive................... : Yes SED Info read........................... : Ok Master Password......................... : No User Password........................... : No SED tech mode lock...................... : No UA writing.............................. : Granted DCM in module 47........................ : ZE DCM in module 0A........................ : |W|MZEDH2F DCM in module 02........................ : S|BWL|PMMZHECDRHV2KBUN
HERE IS THE LOG WHEN DECRYPTING
Quote: SED key checking Key 018D................................ : Module 18D not found Key 018E................................ : Module 18E not found Encryption.............................. : Self Encryption HDD v2 Key 018D................................ : Module 18D not found Key 018E................................ : Module 18E not found SED key checking Key 018D................................ : Module 18D not found Key 018E................................ : Module 18E not found Key 018D................................ : Module 18D not found Key 018E................................ : Module 18E not found External encryption key checking UA key reading:7 813 965 856............ : Ok SA key reading:Copy 0................... : Ok SA key reading:Copy 1................... : Ok UA key reading:7 813 967 235............ : Ok SA key reading:Copy 0................... : Ok SA key reading:Copy 1................... : Ok UA key reading:7 813 965 832............ : Ok SA key reading:Copy 0................... : Has been already read SA key reading:Copy 1................... : Has been already read UA key reading:7 813 971 592............ : Ok
HERE IS CODE WHEN BUILDING HEADS MAP
Quote: Reading method.......................... : VSC command (T2 Data read) T2 read................................. : Ok Zone type............................... : Type 2 Zones................................... : 5 865 SMR zone read........................... : Ok SMR zone indexing....................... : Ok 26 329 / 9.............................. : 193 030 -- 195 885 # 173 119 26 329 / 10............................. : 196 121 -- 196 983 # 173 119 2 296 / 4............................... : 197 227 -- 203 049 # 173 119 2 296 / 12.............................. : 203 050 -- 208 570 # 173 119 38 749 / 5.............................. : 208 571 -- 214 399 # 173 119 41 036 / 4.............................. : 206 153 -- 206 860 # 176 129 58 306 / 4.............................. : 206 861 -- 207 364 # 176 129 58 306 / 7.............................. : 207 365 -- 207 857 # 176 129 ......................STILL MORE AFTER THIS................ MBA <0> to CHS convert error Device Error Detected: "VSC ERR VSC MODE DISABLED"
| Attachments: |
File comment: Quick Disk Analysis
File comment: Green Sector in DE
File comment: Head Map
File comment: Data in Sector Edit After Decryption
File comment: Data in Sector Edit before Decryption
