| ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE http://forum.hddguru.com/viewtopic.php?f=11&t=44106 |
Page 1 of 1 |
| Author: | Data-Salvage [ February 14th, 2024, 21:57 ] |
| Post subject: | ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE |
Hello guys hows your new year? i received this drive that doesnt spin at all and stay BSY with error LED:0x000000BD FAddr:0x000059D8 iv tried the official guide https://blog.acelab.eu.com/how-to-fix-a ... -chip.html but with donor PCB "after Repeat the unlocking steps (1-6) " i cannot enter the command OI1 ..... i will get LED:0x000000BD FAddr:0x000059D8 !AGAIN and if i skip this command and Repeat the unlocking steps (7-9). the drive spinds but i get Waiting drive spin up ! therefore i cannot use the terminal ! with original PCB is the same.....the drive spins if i change to 82 34 56 78 but i cant enter the command OI1 i also noticed that nomatter how many times i write the patient rom into DONOR PCB it will show the SN of the DONOR......... any help will be very very helpfull |
| Author: | lifeguarddubai [ February 16th, 2024, 3:45 ] |
| Post subject: | Re: ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE |
i also noticed that nomatter how many times i write the patient rom into DONOR PCB it will show the SN of the DONOR......... try ROm Programmer to write Patient ROM or change Terminal Speed, Good Luck... |
| Author: | Data-Salvage [ February 17th, 2024, 9:10 ] |
lifeguarddubai wrote: i also noticed that nomatter how many times i write the patient rom into DONOR PCB it will show the SN of the DONOR......... try ROm Programmer to write Patient ROM or change Terminal Speed, Good Luck... programmer ? Sir this drive has no tsop rom on it! the rom is stored inside the nand flash! anyway when i disconnect the pcb from the patient drive it gives me the patient SN but when i connect to the patiend hdd it shows the donor drive SN |
| Author: | pepe [ February 17th, 2024, 11:10 ] |
it has NOR flash (serial flash) albeit not TSOP indeed, but BGA. It is the ~3x2mm chip near the DRAM. ROM is also present in NAND and some parts of it are read from there normally. pepe |
| Author: | Data-Salvage [ February 17th, 2024, 11:58 ] |
pepe wrote: it has NOR flash (serial flash) albeit not TSOP indeed, but BGA. It is the ~3x2mm chip near the DRAM. ROM is also present in NAND and some parts of it are read from there normally. pepe yes right Sir . you 100%...unfortunatelly im stuck.................... maybe non compatible BGA on the donor? but the drive spins when i set 82 34 56 78 however BSY and same terminal error |
