| Sata conversion PCB 2060-810082 http://forum.hddguru.com/viewtopic.php?f=11&t=44222 |
Page 1 of 1 |
| Author: | pclab [ April 8th, 2024, 17:37 ] |
| Post subject: | Re: Sata conversion PCB 2060-810082 |
You need something like this: https://www.hddheadtools.com/wd-smr-hdd ... rd-drives/ |
| Author: | gameboybin [ September 19th, 2024, 21:53 ] | ||
| Post subject: | Re: Sata conversion PCB 2060-810082 | ||
Can you guys pinpoint me what components to remove. I see 4 resistors. Where is the oscillator?
| Author: | gameboybin [ September 19th, 2024, 21:59 ] | ||
gameboybin wrote: Can you guys pinpoint me what components to remove. I see 4 resistors. Where is the oscillator? Found it. Nevermind Remove this components and solder sata like in the post
| Author: | fzabkar [ September 19th, 2024, 22:33 ] |
Leave the crystal alone if you are going to remove the capacitors (not "resistors"). Clearly you have no idea what you are doing or why you are doing it, so perhaps it would be best to outsource this job. Otherwise ... Locating the Reset* pin on USB-SATA bridge ICs: https://www.hddoracle.com/viewtopic.php?f=59&t=3381 |
