fzabkar wrote:posidon wrote:Can someone pls. take remote control to update sysfile 93 as I have given up now & about to return it as unrecoverable.
Try issuing the following terminal commands at level T (
WARNING: commands are Case SenSiTive).
- Code:
F"READ_SPARING_ENABLED",0,22
F"WRITE_SPARING_ENABLED",0,22
F"OFFLINE_SPARING_ENABLED",0,22
F"DAR_ENABLED",0,22
F"DISABLE_IDLE_ACTIVITY",1,22
F"BGMS_DISABLE_DATA_REFRESH",1,22
F"ABORT_PREFETCH",1,22
F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
Thank you fzabkar
here is response for each command --
F3 T>F"READ_SPARING_ENABLED",0,22Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading controller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEFAULTS!
(D) SATA Reset
Byte:0092: Bit:6, READ_SPARING_ENABLED = 0
F3 T>F"WRITE_SPARING_ENABLED",0,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:0092: Bit:7, WRITE_SPARING_ENABLED = 0
F3 T>F"OFFLINE_SPARING_ENABLED",0,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:0455: Bit:1, OFFLINE_SPARING_ENABLED = 0
F3 T>F"DAR_ENABLED",0,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:0455: Bit:0, DAR_ENABLED = 0
F3 T>F"DISABLE_IDLE_ACTIVITY",1,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:0455: Bit:6, DISABLE_IDLE_ACTIVITY = 1
F3 T>F"BGMS_DISABLE_DATA_REFRESH",1,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:010C: Bit:1, BGMS_DISABLE_DATA_REFRESH = 0
F3 T>F"ABORT_PREFETCH",1,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:00DA: Bit:6, ABORT_PREFETCH = 1
F3 T>F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:00E4: Bit:5, READ_LOOKAHEAD_DISABLED_ON_POWER_UP = 1
F3 T>F"READ_CACHING_DISABLED_ON_POWER_UP",1,22Drive AMPS Configuration has been modified from compiled defaults.
(D) SATA Reset
Byte:00DA: Bit:0, READ_CACHING_DISABLED_ON_POWER_UP = 1
F3 T>
