| How to Deselect particular file types & subfolders from DE http://forum.hddguru.com/viewtopic.php?f=11&t=44348 |
Page 1 of 1 |
| Author: | athena [ June 1st, 2024, 2:42 ] |
| Post subject: | How to Deselect particular file types & subfolders from DE |
I want to recover large data having many folders /subfolders & files.In order to minimize time I want to deselect particular file extensions from entire task. How can I skip all particular file extensions as doing it manually is very much time consuming. While I can select particular file extension or folder names from find files /folders in DE so that all those specific files I can copy ,but I want to do opposite want to remove particular file extensions from large no of files. Any suggestion or tip. Thanks |
| Author: | pepe [ June 1st, 2024, 3:09 ] |
| Post subject: | Re: How to Deselect particular file types & subfolders from |
can't you simply select all, then use find files as you wrote and deselect the result? |
| Author: | athena [ June 1st, 2024, 3:37 ] |
pepe wrote: can't you simply select all, then use find files as you wrote and deselect the result? Thanks pepe Yes that's good solution ,I will have to select each required file type & recover & repeat this exercise .Is it possible to select multiple file types at a time (*.xls ,*.jpg ,*.pdf ,*.doc,*.xlsx etc ) then that will solve my purpose. |
| Author: | pepe [ June 1st, 2024, 6:41 ] |
i think finding multiple templates is allowed, separated with semicolon, then you select files in result. |
| Author: | athena [ June 1st, 2024, 8:02 ] |
pepe wrote: i think finding multiple templates is allowed, separated with semicolon, then you select files in result. OK great that will save lots of my time. I have to select single head out of 4 & do imaging of all required files & skip others 4 times .I have tried earlier but instead of semicolon I put comma . I thought its not supported. Thanks a lot pepe |
