HDD GURU FORUMS
http://forum.hddguru.com/
Western Digital does not access user data
http://forum.hddguru.com/viewtopic.php?f=11&t=44420
Page 1 of 1
Author:  Protech [ June 20th, 2024, 8:07 ]
Post subject:  Western Digital does not access user data
Hello everyone,
I tried to recover 2.5 western digital Drive, Model number WD20SPZX, When I try to access the files in DE, there is no user data available. I perform T2 recovery and backup modules and SA, The sectors look good on sector edit, also module 01A Error occurred. Could you please advise.
Thanks.
Author:  pepe [ June 20th, 2024, 8:43 ]
Post subject:  Re: Western Digital does not access user data
If sectors look ok, what is the problem for which you need advice?
Author:  Lukas [ June 20th, 2024, 8:44 ]
The drive was blocked from access to SA by default?
Can you post a screenshot of the T2 reading?
How many percent does the tool say is filled with zeros after T2 reading?
Author:  lifeguarddubai [ June 20th, 2024, 9:06 ]
hi @protech
if sector looks okay and you cant see file structure could be logical issue take full image and scan for lost Partition.
Author:  Protech [ June 21st, 2024, 2:56 ]
Hi pepe, appreciate the response. The problem is I'm getting an error entering DE and no access to client's data. I have attached the screen shots of the errors. Sectors are read using utility.
File comment: Read using utility. whole sectors are read fully
File comment: DE entered without drive ID
File comment: Trying to enter DE with Drive ID checked
Author:  Protech [ June 21st, 2024, 2:59 ]
The heads seem to write ok.
Author:  pepe [ June 21st, 2024, 3:11 ]
VSC_UNSUP_ACTION_CODE occurs when ovl is not loaded, so i suppose the drive restarted coz of some error and stayed without ovl. what does status sector say?
Author:  Protech [ June 21st, 2024, 3:31 ]
Please forgive my ignorance but do you mean this?
Author:  Protech [ June 24th, 2024, 11:03 ]
Hi guys, any idea in this case?
Author:  Mikippp [ June 24th, 2024, 13:50 ]
Tools -> Utility extensions -> HDD State
Mikippp
Author:  Protech [ June 26th, 2024, 2:13 ]
Mikippp
Thank you Mikippp :mrgreen:
Author:  Protech [ June 26th, 2024, 2:22 ]
Here is the HDD state
HDD Info.docx [22.78 KiB]
Downloaded 250 times
State Sector.docx [26 KiB]
Downloaded 249 times
Author:  Protech [ July 4th, 2024, 7:38 ]
Any help on this drive is much appreciated.
http://www.phpbb.com/
