"dell" st4000nm016a diagnostic port locked
http://forum.hddguru.com/viewtopic.php?f=11&t=44484
Author:  beefstrudel [ July 18th, 2024, 10:22 ]
Post subject:  "dell" st4000nm016a diagnostic port locked
Does anyone know how to unlock tech mode on these drives? The ROM is not a standard Seagate ROM so PC3000 cannot patch it, F3romExplorer just crashes when I try to open it there.
Author:  Lukas [ July 18th, 2024, 11:00 ]
Post subject:  Re: "dell" st4000nm016a diagnostic port locked
It would be easier to say something if you added this ROM for verification...
Author:  fzabkar [ July 18th, 2024, 11:04 ]
The only time I've seen F3romExplorer crash is when the ROM is corrupt.
Author:  beefstrudel [ July 18th, 2024, 11:39 ]
Sorry I forgot to post the ROM :lol:
I have 2 reads in this zip file, one with pc3k and one directly with an eeprom programmer
File comment: 2 separate read of a rom file from a dell branded seagate st4000nm016a
1A42EBA7.7z [378.46 KiB]
Downloaded 349 times
Author:  fzabkar [ July 18th, 2024, 12:20 ]
Offset 0 - 0x3FFFF is corrupt. I have replaced it with 0x40000 - 0x7FFFF.
ROM-1A42EBA7-Direct Read_edited.7z [370.67 KiB]
Downloaded 403 times
ROM-1A42EBA7-PC3K read_edited.7z [368.87 KiB]
Downloaded 339 times
Author:  beefstrudel [ July 18th, 2024, 12:53 ]
Thank you! Now when I try to do the tech mode unlock patch pc3k doesn't have any issues with it.
But after patching I get
"Flash boot code Digital Signature Verification failure!
Flash boot code checksum failure!"
I've tried patch type 2 as well with the same result. I'm just trying to unlock so I can edit SMP.
Author:  fzabkar [ July 18th, 2024, 13:18 ]
I expect that PC3000 will have the same problem with a ROM from a working donor.
Author:  beefstrudel [ July 18th, 2024, 13:30 ]
Unfortunately I don't have any donors for this drive on hand. The drive works and I can get a sector to read immediately after power on with the fixed ROM you posted. I just cant seem to unlock tech mode. PC3000 log says the patch went ok but the terminal just outputs that boot code signature error.
Edit: I think the issue may be my PC3000 version, I only have 6.9.16 and this is a B5 Cimarron drive.
Author:  fzabkar [ July 18th, 2024, 13:35 ]
The digital signature is in the BOOTFW segment. PC3K modifies this segment to install its tech mode handshake patch. I expect that this extra code invalidates the digital signature.
Author:  beefstrudel [ July 18th, 2024, 14:07 ]
Makes sense. Thanks for the help! So frustrating being locked out of an easy fix :(
