 Post subject: RayMX RM1135
PostPosted: August 2nd, 2024, 11:30
i have a chinese SSD Sata and it has RayMX RM1135 when i connect it to the PC3K it reads it normally with all info but with reading is very very slow and when i repower the SSD manually it can read the unreadable sectors but very slow is there and suggestions to solve that ?
 Post subject: Re: RayMX RM1135
PostPosted: August 2nd, 2024, 12:03
No solutions for Realtek to work in techno mode. Copy important data as fast as possible. Set proper timing, resets, repowers etc. Try with a little heat or freezing spray on nands.
odzyskiwanie danych
PostPosted: August 2nd, 2024, 12:05
Cover the entire ssd leaving the nand chips ,Then use hot air or freeze whatever works .if reading is slow nand is degrading
PostPosted: August 2nd, 2024, 12:28
thank you for your replays
but i tried those suggestions it gives same results, it reads about 0.5 mb in 30 min
:roll:
Users browsing this forum: No registered users and 14 guests
