HDD GURU FORUMS
http://forum.hddguru.com/
Rosewood A5 Busy & LED dignostics
http://forum.hddguru.com/viewtopic.php?f=11&t=44533
Page 1 of 1
Author:  MISU [ August 1st, 2024, 1:38 ]
Post subject:  Rosewood A5 Busy & LED dignostics
This disk doesn't make clicking noise neither spin down can it get fixed on FW level or the issue is deeper with Heads
Model - Seagate 2.5" Barracuda (Rosewood A5) ST1000LM048
Author:  northwind [ August 1st, 2024, 3:26 ]
Post subject:  Re: Rosewood A5 Busy & LED dignostics
Most probably yes.
Author:  MISU [ August 1st, 2024, 3:53 ]
northwind wrote:
Most probably yes.
Thanks northwind
I will unlock & give it a try
Author:  MISU [ August 2nd, 2024, 1:37 ]
Disk stays in busy state & is not coming to terminal . Does this case needs anything extra like shorting
Author:  michael chiklis [ August 2nd, 2024, 2:10 ]
Verify your 3D virtual loader version with your rom version, they must match.
You can compare theyr date, if 3D and rom date are the same then it means that your 3D loader is compatible with your drive.
Watch this video i made:
https://www.youtube.com/watch?v=P2Fcr71LUqs
Author:  michael chiklis [ August 2nd, 2024, 8:22 ]
Sorry, i wasn't clear.
To match 3D loader and rom versions, you need to compare patient rom with donor drive rom.
Author:  MISU [ August 2nd, 2024, 11:56 ]
A unique solution ,I was not aware of this. Thanks a lot for sharing.
http://www.phpbb.com/
