RayMX RM1135
http://forum.hddguru.com/viewtopic.php?f=11&t=44538
Author:  Core.iStores [ August 2nd, 2024, 11:30 ]
Post subject:  RayMX RM1135
i have a chinese SSD Sata and it has RayMX RM1135 when i connect it to the PC3K it reads it normally with all info but with reading is very very slow and when i repower the SSD manually it can read the unreadable sectors but very slow is there and suggestions to solve that ?
Author:  melvin [ August 2nd, 2024, 12:03 ]
Post subject:  Re: RayMX RM1135
No solutions for Realtek to work in techno mode. Copy important data as fast as possible. Set proper timing, resets, repowers etc. Try with a little heat or freezing spray on nands.
Author:  Amarbir[CDR-Labs] [ August 2nd, 2024, 12:05 ]
Cover the entire ssd leaving the nand chips ,Then use hot air or freeze whatever works .if reading is slow nand is degrading
Author:  Core.iStores [ August 2nd, 2024, 12:28 ]
thank you for your replays
but i tried those suggestions it gives same results, it reads about 0.5 mb in 30 min
:roll:
