 Post subject: Toshiba DT01ACA100 (Hitachi ) Diagnostics
PostPosted: September 14th, 2024, 7:40
Toshiba DT01ACA100 ( Hitachi ARM ) is having no spin & is getting detected as 0mb with no model no & SN bu showing FW.
What could be the issue ? Is this FW or head related issue.
Can someone pls. comment. Thank you
 Post subject: Re: Toshiba DT01ACA100 (Hitachi ) Diagnostics
PostPosted: September 14th, 2024, 13:12
PUIS is enabled.
PostPosted: September 15th, 2024, 4:22
PUIS is enabled.
Thanks a lot fzabkar :D :good:
In a second drive started to get ready. I was about to give a quotation for head transplant
you saved a job & a customer too.
