ST500LM000 Busy
http://forum.hddguru.com/viewtopic.php?f=11&t=44714
Author:  Core.iStores [ October 2nd, 2024, 7:40 ]
Post subject:  ST500LM000 Busy
i have an issue with ST500LM000 PCB it gives "SMI Init (or) Training Failed 0x000000D2" in terminal & PCB No. is "100705349 REV D"
i replaced it with PCB "100731589 REV A" after clearing the NAND and swapping the ROM Chip
the issue is the donor PCB keeps BUSY all the time with no access to terminal
can any one help me with this please ?
Author:  Lukas [ October 4th, 2024, 5:15 ]
Post subject:  Re: ST500LM000 Busy
How did the disk behave before the PCB replacement?
Have you read the PC3000 manual for the F3 section 4.4?
Author:  MindMergepk [ October 4th, 2024, 10:56 ]
perhaps you need the same REV as patient, never tested on different REV.
