Page 1 of 3
Repair the pc-3000 UMDA
Posted: November 22nd, 2024, 0:57
by Data-Salvage
Hello guys did anyone ever fixed the pc-3000 UMDA? sata 1 doesnt work but not cable problem! iv replaced the 88SA8052 but still the same! any suggest?
Re: Repair the pc-3000 UMDA
Posted: November 22nd, 2024, 1:23
by fzabkar
If you upload detailed photos of the boards, I'll try to help you.
Posted: November 26th, 2024, 1:41
by Data-Salvage
i just noticed the IC that i replaced is different....... my bad! cant find a compatible IC "the one in the LEFT" is the original chip!
Posted: November 26th, 2024, 1:53
by HaQue
that chip has a test/debug port. You might be able to see whats happening on it. Also probably not that chip thats the issue. Do what Fzabkar suggest and upload pic of the board
Posted: November 26th, 2024, 14:44
by fzabkar
The difference is in the package code (TBC versus TJC):
https://www.hddoracle.com/download/file.php?id=5485&mode=view
In fact, Ace Lab recommends the JMicron 20330 IDE-SATA bridge.
https://www.hddoracle.com/viewtopic.php?p=24565#p24565
Similar issue here:
https://www.hddoracle.com/viewtopic.php?p=16899#p16899
Posted: November 26th, 2024, 15:07
by fzabkar
Posted: November 26th, 2024, 22:14
by Data-Salvage
thank you for your time answering Sir
the JMicron 20330 has no soldering point on the back side! is same with the TBC version that i bought! iv already tested the other components on the board with the multimeter !and compared with another pc-3000! they measure correctly!
that is why im pretty sure the problem is the 88SA8052-TJC2 controller! but i cant find it on sale on aliexpress! what about the 88sa8052-nnc2 ? is suitable? looks similar
fzabkar wrote:The difference is in the package code (TBC versus TJC):
Similar issue here:
Posted: November 26th, 2024, 22:21
by fzabkar
I saw the -NNC2 version in my searches. I don't have a datasheet, but I'm guessing its pinout would be identical. I really don't see how the extra heat sinking would make a difference, though. If you're worried, you could glue a heatsink to the top of the IC.
Be aware that there are a lot of fakes at Aliexpress.
Does the drive spin up on the faulty port?
Posted: November 26th, 2024, 22:42
by Data-Salvage
thank you for your super fast answer! i tought the soldering point on the back side of the chip are some sort of "grounding"
the drive spins but on the pc-3000 utility STATUS REGISTER status it looks like nothing is connected
you think the 20330, or the 88SA8040-TBC1 will be compatible?
PS sorry for my bad english
Posted: November 26th, 2024, 23:02
by fzabkar
I can't say whether they all have the same pinout, but it would be very odd if they didn't. The JMicron chip is mostly the same, but there are some differences. You need to examine that schematic diagram at the HDD Oracle to see what they are. Are you sure that the Spartan chip is OK?
Posted: November 26th, 2024, 23:18
by Data-Salvage
you mean the TPS 2590? they all give me the same voltage Sir
fzabkar wrote:I can't say whether they all have the same pinout, but it would be very odd if they didn't. The JMicron chip is mostly the same, but there are some differences. You need to examine that schematic diagram at the HDD Oracle to see what they are. Are you sure that the Spartan chip is OK?
Posted: November 27th, 2024, 2:17
by Data-Salvage
iv swapped the 88SA8052-TJC2 controller of sata o to sata 1!
sata 0 work but sata 1 still doesnt work!.. maybe is not a problem with controller?
Posted: November 29th, 2024, 0:43
by Data-Salvage
any suggestion guys? maybe capacitors?
Posted: November 29th, 2024, 1:11
by fzabkar
I'm wondering whether the problem is in this IC:
Alternatively, maybe one of the SATA Tx/Rx coupling capacitors is open? You could test this by shorting the ends of each capacitor with tweezers. (However, you mustn't do this if you have also removed the same capacitors on your USB HDD, for example.)
I can't imagine that the problem is in the power section. If there was a problem with that section, then I would think that the drive wouldn't spin.
Posted: November 29th, 2024, 17:35
by michael chiklis
Does pc3k have ic TPS2590 as mrt?
Maybe this will help you:
https://forum.hddguru.com/viewtopic.php ... le=desktop
Be carefull, if you buy ic from china (example a package that contains 10 units), 5 or 6 of them are often fake or not good !!
After i replaced that ic on ATA1 port of my mrt, power port issue got even worse, but i knew that it could be due to fake ic... so i replace the same ic again and finally mrt port got to work again.
Posted: December 2nd, 2024, 1:22
by Data-Salvage
Sir thank you for your patience.... actually the capacitors of SATA 0 and SATA 1 give me different values
Posted: December 2nd, 2024, 1:58
by Data-Salvage
does enybody know the capacity and voltage of those Aluminum Electrolytic Capacitor??????? looks like 150uf but im not sure about the voltage.... 16V?? i can find locally with same value but the sizes are different...
Posted: December 2nd, 2024, 2:01
by fzabkar
Check the IC's supply voltage? 25MHz crystal clock?
Posted: December 2nd, 2024, 2:31
by Data-Salvage
Sir i don't understand the meaning of this difficult terms! what are crystals???
fzabkar wrote:Check the IC's supply voltage? 25MHz crystal clock?
Posted: December 2nd, 2024, 2:33
by fzabkar
