| ST1000LM038 in external UltraTouch Backup plus is locked http://forum.hddguru.com/viewtopic.php?f=11&t=44939 |
Page 1 of 1 |
| Author: | fzabkar [ December 12th, 2024, 0:52 ] |
| Post subject: | Re: ST1000LM038 in external UltraTouch Backup plus is locked |
Experiment with the new drive. Compare the contents of the SA and USB flash memory before and after locking. How many sectors does the USB mass storage device report to the OS? Is it less than the native capacity of the HDD? If yes, then there must be some reserved space at the end of the UA which is being used by the bridge firmware. |
| Author: | WalRos [ December 12th, 2024, 7:52 ] | |||
| Post subject: | Re: ST1000LM038 in external UltraTouch Backup plus is locked | |||
I check sector counts with unlocked over USB-adapter and on SATA direct (locked), only one is the different (pls see attachment). I can SA only check on SATA direct (locked) because SA reading is only possible in "Tech Mode" (Patch) and what do you mean with "USB flash memory"?
| Author: | fzabkar [ December 12th, 2024, 12:13 ] |
Sorry, I meant the 8-pin serial flash memory ("ROM") on the USB-SATA bridge PCB. It looks like the bridge firmware is reporting one less sector, so perhaps there is something in that last sector. |
| Author: | WalRos [ December 16th, 2024, 11:37 ] |
I can read the ROM with my "RUS V5000" on the USB-SATA bridge PCB only if the USB kabel is not connected. |
| Author: | fzabkar [ December 16th, 2024, 18:22 ] |
Where is the password stored, if anywhere? |
| Author: | WalRos [ December 17th, 2024, 6:06 ] |
it must be on the hard drive because I try the patient USB-SATA bridge on the new drive and I can unlock the new drive with patient USB-SATA bridge |
