Grenada Firmware repair
http://forum.hddguru.com/viewtopic.php?f=11&t=44984
Author:  terminator2 [ January 4th, 2025, 6:36 ]
Post subject:  Grenada Firmware repair
I have Grenada 58 family disk ST500DM002 -C45 , I am unable to get firmware access & hence proper sector access ( sector can be read but lots of defects even in MFT's)
What should I do now.
Author:  michael chiklis [ January 4th, 2025, 8:20 ]
Post subject:  Re: Grenada Firmware repair
locked firmware?
Check in terminal if does accept commands.
If fw is locked, when you send commands on terminal, it will respond "locked"
Author:  terminator2 [ January 4th, 2025, 8:49 ]
michael chiklis wrote:
locked firmware?
Thanks michael
I can issue command so it seems is not firmware locked but I cannot access any system files .
Author:  michael chiklis [ January 4th, 2025, 12:36 ]
you can send commands also if is locked, but if is locked it returns "locked".
For example, you can check if P-list is available with command V10 in level T if fw is not locked.
Does it show P-list log in terminal if you send V10 command?
Author:  terminator2 [ January 5th, 2025, 5:38 ]
I get DiagError for both V10 & V40 commands.
Author:  SWM [ January 5th, 2025, 9:19 ]
Switch the power without turning off the terminal.
Then press Ctrl Z and Ctrl X.
This log will be more informative. Apparently (5104), not everything is read in the CA
Author:  terminator2 [ January 5th, 2025, 11:57 ]
Thanks SWM
I tried this there is slight change in terminal message now
F3 T>V10
DiagError 00005104
DiagError 00005104
Invalid Diag Cmd Parameter
F3 T>
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:001B
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Author:  ccc [ January 6th, 2025, 4:27 ]
After entering T> level press Ctrl+X and post here the result.
Author:  terminator2 [ January 6th, 2025, 9:04 ]
Thanks ccc
Nothing happens after CTRL+X .Drives does not show any output .It responds to CTRL+Z only.
Author:  SWM [ January 6th, 2025, 10:23 ]
Select the correct (USB-TTL) terminal voltage level.
I don't know how to do this on the PC3000.
Check the connections.
Author:  terminator2 [ January 11th, 2025, 3:13 ]
Thanks SWM
Finally only after head change I could recover data.
