 Post subject: About Seagate Rosewood smr..
PostPosted: December 24th, 2024, 4:46
I've studied loadwood or smr storage.
I even understood storing data on a platter like a roof.
So to restore the translator, if you back up the system 1b 28 35 93 and remove the g-list and recreate the translator, the translator will be restored. If you overwrite the g-list module where it was restored, can you save the g-list partial data? Or is it impossible to recover? I just don't understand this part. Is there a way to understand?
 Post subject: Re: About Seagate Rosewood smr..
PostPosted: December 24th, 2024, 9:41
Have you got the professional data recovery tool available with you?
whats the symptom of the hard drive?
Best Regards,
Murtaza H.
Data Recovery Dubai
PostPosted: December 25th, 2024, 20:23
yes
i have pc3000
It's terminal error,
EDAC Value = 000000001B7ECF70
EDAC Value = 000000001B7ECF70Out:
Unrecoverable Error Reported
Unrecoverable Read Verify Error Reported
Starting LBA of RW Request=001D1C1115 Length=FFFFFFFF
ProcessRWError -Read- at LBA 001D1C1115 Sense Code=44090082
Common path start quit now
EDAC Value = 000000001B7ECF70ProcessRC: 00000001,00000000[Host]ReadContinuous: 1D1C10EB,0000002BUnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000,00000000Passed(Host): 00000080,00000022Out: OfflineOC
SP Regen FAIL
SPRegen [0000|04090092] @LBA=0x1D1C1115
Setup currentretry count
Hd 2 Err Blk 1D1C1115 BER pre -1.881616
PowerState = IDLE1
VC0
(DOS) File Save Wrst Ct: 0000 SU: FFFFFFFF NT: 00000000 OT: 00000000
HighPowerMode
XI2
VC1
VC2Up:Status 0001 Req 0002
PowerState = IDLE2
VC0
PostPosted: December 26th, 2024, 11:39
have you tried changing new heads?
"Hd 2 Err Blk 1D1C1115 BER pre -1.881616"
head#2 is bad.
Best Regards,
Murtaza H.
Data Recovery Dubai
PostPosted: December 26th, 2024, 21:53
head#2 is bad.
Does the unc error also appear in case of head problem?
