SSD PC SATA-PATA Bridge Errorr
http://forum.hddguru.com/viewtopic.php?f=11&t=45088
Author:  LostDataSa [ February 5th, 2025, 8:54 ]
Post subject:  SSD PC SATA-PATA Bridge Errorr
Hi I have a Kingstone SATA SSD with CP33238B
but after shorting the pin to start Safe mode I get this error
I am using Acelab PC PATA-SATA
Author:  Lukas [ February 5th, 2025, 9:48 ]
Post subject:  Re: SSD PC SATA-PATA Bridge Errorr
And when starting the program you select the appropriate PATA port, not SATA?
Author:  LostDataSa [ February 5th, 2025, 12:30 ]
Yes
Author:  Lukas [ February 6th, 2025, 3:00 ]
The message clearly suggests using the application's SATA port rather than the PATA port.
If everything is connected correctly on original Acelab adapters contact their support.
Author:  pepe [ February 6th, 2025, 3:21 ]
No, the message says the utility has problems getting data through the INTERNAL (on-board, marvel 88SA8052) PATA-SATA bridge and suggests to use one of the PATA ports with the jmicron PATA-SATA (JMS20330) bridge attached. You also need to start the util using the PATA port.
Author:  Lukas [ February 6th, 2025, 4:02 ]
That's exactly what I mean.
Author:  LostDataSa [ February 9th, 2025, 10:37 ]
I am using the original PATA-SATA that came from Acelab
