Terminal adapter header pitch.
http://forum.hddguru.com/viewtopic.php?f=11&t=45210
Author:  Lardman [ March 25th, 2025, 9:47 ]
Post subject:  Terminal adapter header pitch.
Can anyone confirm the pitch of the female header that plugs in the drive on the PC3000 WD terminal adapter connectors - specifically the WD sata one. My callipers say 1.7mm but I can't find anything online.
Mines has somehow got mashed and I don't fancy paying Ace prices for a new adapter when it's just a 4 pin connector that needs replacing.
Author:  lcoughey [ March 25th, 2025, 10:45 ]
Post subject:  Re: Terminal adapter header pitch.
All you need are two jumper wires to connect tx/rx between the PCB and the USB terminal adapter.
Author:  Lardman [ March 25th, 2025, 11:13 ]
I know but Im still going to need smaller than the standard duponts to grip the pcb header pins, I might as well replace the connector and do it properly.
Author:  lcoughey [ March 25th, 2025, 12:02 ]
I just removed the square plastic off one end and replace it with shrink tubing. Makes it small enough for the PCB side of things and the square plastic is a great fit for the terminal adapter.
Author:  pepe [ March 26th, 2025, 1:48 ]
it shouldn't be so complicated to measure the pitch... possibly measure it between the leftmost and rightmost one and divide it by the n-1 where n is num of pins.
it gives me 2mm pitch.
take pin width into account, pitch is measured at center line of pin.
Like Luke, i also used wires+sockets removed from 2mm pitch array, with shrink tubes, for more flexibility, whatever the pinout is...
Author:  pclab [ March 26th, 2025, 4:06 ]
Here you can get all 8 cheap.
https://www.drivestar.biz/index.php?mai ... 4esn5qlht6
Author:  Lardman [ March 26th, 2025, 4:57 ]
@Pepe - I was essentially doing that but I have a mashed mess for pins, not sure how but I've lost the plastic surround - it's probably stuck in a drive pcb somewhere.
I'll give you it's not as flexible, but a nice fat 4 pin connector is a lot easier for me to work with than fly lead nowadays - one less swap of the glasses :oops: .
