HDD GURU FORUMS
http://forum.hddguru.com/
[SELL] PC3K Portable System III SSD + PC3K Flash RUSSIAN VER
http://forum.hddguru.com/viewtopic.php?f=11&t=45355
Page 1 of 1
Author:  hddfrei [ May 28th, 2025, 12:39 ]
Post subject:  [SELL] PC3K Portable System III SSD + PC3K Flash RUSSIAN VER
I have for sale a set in the Russian version of PC III Portable SSD and PC3000 Flash Basic Package + Spiderboard. You can work with HDD 3'5, HDD 2'5, SSD, M.2, NVME and memory flash. To use this version of PC3000 you need to know Russian language.
The set is used, everything works. The set was bought for the Russian market, therefore the software is in Russian.
I will provide login data in ACELAB. DATA IN THE SYSTEM CANNOT BE CHANGED.
When working with disks and problems, you can buy annual support for PC3000 III Portable SSD - as part of the support, you can report 5 problems/month to the specialist to solve, and after connecting via Anydesk/Teamviewer to the computer/PC3000, he will take care of recovering the data. For PC3000 III Flash, you can also report 5 tickets. The cost of annual support for both systems is about $1000.
After purchase, I will provide the contact to the person responsible for support PC3000
WORKS WITHOUT BUYING SUPPORT!
PC-3000 Flash Basic Package + Spider Board Adapter.jpg [ 521.1 KiB | Viewed 992 times ]
http://www.phpbb.com/
