Page 1 of 1
WD charger USB C to sata conversion HELP PCB PCB 2060-81003
Posted: June 19th, 2025, 2:58
by Data-Salvage
hello there i came across one page regarding "usb C to SATA" conversion by blizzard data for the PCB 2060-81003-001 REV P1 i believe the wiring is correct however i saw another post by chinese person were they did soldering on different PIN numbers so got confused..... do someone know which one is the correct? sorry im getting old
Re: WD charger USB C to sata conversion HELP PCB PCB 2060-81
Posted: June 19th, 2025, 5:04
by digisupport
Looks identical to me.
Posted: June 19th, 2025, 8:34
by Data-Salvage
digisupport wrote:Looks identical to me.
thank you for the answer Sir. i dont know which wiring is the correct for my PCB
i found two different wiring on the web but im confused...can you tell me which one is the correct?
Posted: June 20th, 2025, 3:18
by digisupport
The two pictures are showing the same
WD SG SATA-USB
Posted: June 20th, 2025, 12:47
by fzabkar
I would find a photo of a SATA PCB with the same MCU and follow the SATA Tx/Rx pins from the SATA connector back to the MCU.
