 Post subject: Power Monitor
PostPosted: June 27th, 2025, 9:13
Primitive question please,
where to find the "Power Monitor" in PC-3K.
As per ACE-Lab Tutorial one needs to double click on the 3v/5v green lights.
I did, unfortunately nothing popped up!!
 Post subject: Re: Power Monitor
PostPosted: June 27th, 2025, 13:15
Only available on express & portable.
PostPosted: June 27th, 2025, 16:59
In order to monitor the current, there would need to be a current monitor IC or ADC. All I see in the power section are 4 ordinary load switches (TPS2590).
https://www.hddoracle.com/viewtopic.php?p=16912#p16912
PostPosted: June 28th, 2025, 4:33
really, never knew this!
thanks by the way
PostPosted: June 28th, 2025, 4:37
No fzabkar, I'm speaking about current monitoring window. It's pc-3k udma and everything seems fine with it as it provide both 3v and 5v as it's shown in new attached image.
PostPosted: June 28th, 2025, 12:42
@Recover-IT, there is no current monitoring circuitry that I can see. As for 5V and 3V, I think you meant 5V and 12V. In any case, this just means that PC3K has turned on each rail via the two load switches that I mentioned previously. Pin #16 is the Enable input.
https://www.hddoracle.com/download/file.php?id=6738&mode=view
https://www.hddoracle.com/download/file.php?id=6737&mode=view
I can't see how PC3K can sense the actual voltages -- there doesn't appear to be any ADC circuitry for this either. The load switch has a Fault output on pin #15. PC3K could sense this pin to determine whether either rail has shut down.
PostPosted: June 28th, 2025, 13:15
Here are photos of the PC-3000 Express Intelligent Power Supply Unit:
https://www.jandatech.pl/wp-content/uploads/2023/09/jandatech-pcexpress.jpg
https://www.acelab.eu.com/images/instraction/10.png
https://www.tracip.fr/wp-content/uploads/2020/11/pc3000express1-1440x730.jpg
There are 8 load switches. I expect that these have a current monitor output which is monitored by the main QFP IC and transmitted to the Spartan-6 FPGA. UDMA has nothing like this.
PostPosted: June 29th, 2025, 10:06
Hi fzabkar
Thanks for your replay, however I'm speaking on the Software lever and not hardware.
As Lardman mentioned, this fonction is not supported in PC-3000 UDMA. Only in protable and express.
PostPosted: June 29th, 2025, 14:49
Yes, I understand. I'm just confirming that there is no support in your PC3K hardware for a power monitor.
PostPosted: June 29th, 2025, 15:36
ic! Thanx by the way
Users browsing this forum: No registered users and 28 guests
