 Post subject: Rosewood AF issue
PostPosted: June 27th, 2025, 8:34
Hello
While unlocking rosewood & writing rom AF family disk PC accidentally restarted & disk stays busy now.
I have this strange issue always even after successful patching & writing each time disk doesn't get normal ID .
Now while entering in utility & powering it gets unlocked .I have worked on sys file 93 as well.
However I am encountering bad sectors and imaging is not smooth.
What else I should do to further refine sector access ? Can someone pls. guide.
Thank you.
 Post subject: Re: Rosewood AF issue
PostPosted: June 27th, 2025, 9:19
There is media damage on surface 1.
PostPosted: June 27th, 2025, 9:51
Oh Thanks northwind , I am currently imaging drive , is anything on FW level will help ?
PostPosted: June 29th, 2025, 20:39
We can tune this up remotely
Zero Alpha: zeroalpha.com.au
PostPosted: June 30th, 2025, 9:15
Thank you so much :D :beer:
Users browsing this forum: No registered users and 6 guests
