 Post subject: Donor Resources: HTS541010A7E630 Drive with MU-code J4H0
PostPosted: July 14th, 2025, 14:45
I am working on a HTS541010A7E630 drive with an unreadable USAG module, which prevents the SA modules from loading. To proceed, I need to initialize the drive using compatible donor resources uploaded into RAM. The donor must be from the same model (HTS541010A7E630) and have the same MU-code in NVRAM — the last 4 symbols in the NVRAM dump should be J4H0.
If you have such donor resources available, could you please share them or assist with this case?
Thank you in advance for your help!
Best regards,
MACROFER - data recovery
 Post subject: Re: Donor Resources: HTS541010A7E630 Drive with MU-code J4H0
PostPosted: July 14th, 2025, 14:47
Family: Hitachi-ARM-IBM 5450A7
https://hex-serwis.pl/en/firmware
Users browsing this forum: No registered users and 145 guests
