 Post subject: WDC WD5000LPVX-08VOTT5 erro firmware
PostPosted: January 8th, 2026, 6:34
I have a WDC WD5000LPVX-08V0TT5 500GB HDD, but when I connect it to a PC using PC-3000, it only shows 160GB.
 Post subject: Re: WDC WD5000LPVX-08VOTT5 erro firmware
PostPosted: January 8th, 2026, 10:40
Has it been set a DCO / HPA?
That would explain the reduced size.
Check also if mod 02 has been modified.
Why are you using pc3k SAS instead SATA for this drive?
My firmware database:
