 Post subject: Unable to clear SMP flags
PostPosted: August 31st, 2025, 9:13
Hi
I am getting errors while clearing SMP flags , can someone pls. help.
 Post subject: Re: Unable to clear SMP flags
PostPosted: August 31st, 2025, 13:54
You could try issuing the following Case Sensitive commands at Level T.
F"READ_SPARING_ENABLED",0,22
F"WRITE_SPARING_ENABLED",0,22
F"OFFLINE_SPARING_ENABLED",0,22
F"DAR_ENABLED",0,22
F"DISABLE_IDLE_ACTIVITY",1,22
F"BGMS_DISABLE_DATA_REFRESH",1,22
F"ABORT_PREFETCH",1,22
F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
PostPosted: August 31st, 2025, 20:19
F"DAR_ENABLED",0,22
Thanks fzabkar , I am hopeful it will work. :good:
PostPosted: August 31st, 2025, 22:43
Thanks fzabkar , I am hopeful it will work. :good:[/quote]
Can these commands make permanent changes or in Ram only , I have given all commands but changes are not reflected in sysfile , drive has same symptoms.
PostPosted: September 1st, 2025, 2:05
maybe i can't see the obvious, but what symptoms do you mean?
SMPs didn't get changed after issuing those commands. Didn't you apply wr protect patch by any chance?
PostPosted: September 1st, 2025, 8:33
Thanks a lot pepe
After issuing commands when I try to get sector access disk becomes busy & readyness is lost. Also when I check sysfile 93 all unchecked flags are not actually cleared.
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F) and MCMT not available error is also displayed
i
PostPosted: September 2nd, 2025, 2:53
Frustrated with drives behavior I outsourced this case & got a reply that Head 1 is weak & drive is having large TEC sectors , recovery will be partial & will need head transplant
PostPosted: October 9th, 2025, 11:08
bunty wrote:
Hi
When editing SMP flags on rosewoods you need to do it via ATA, not terminal in the drop down menu. It will trhow not supported by firmware. You use the normal "edit HDD ID" in the drop down. Alternatively you could read the module, edit it and write it back under work with rom.
Or you can issue terminal commands as stated above. Though if this is a rosewood SSHD you must disable flags via terminal commands otherewise you brick the drive.
Weak head can also cause this but there is probably more if this is a partial. May be really bad platter conditions or platter damage on that head.
Remember, take your time. Be persistent. If you have doubts stop. Check, then proceed again.
PostPosted: October 11th, 2025, 11:15
Omega wrote:
bunty wrote:
Hi
Thanks Omega
I will remember ATA settings . I feel its better to use terminal commands each time.
