PLEASE help me to unlcok ROM for WD60PURX-64T0ZY1
Posted: June 8th, 2026, 7:53
Hi, PLEASE help me to unlcok ROM for WD60PURX-64T0ZY1
rom file as attached,
thanks in advanced!!
Data recovery and HDD repair discussions
http://forum.hddguru.com/
arroo wrote:Hi Lukas,
Thank you for the reply, the HDD has bad sectors,
when I do selfscan, the HDD went dead after new ROM been written,
I guessed maybe the ROM need to be unlocked.
Maybe the firmware of selfscan is not right.
Lukas wrote:What exactly did you do and what tool did you use?
michael chiklis wrote:arroo wrote:Hi Lukas,
MRT, right?![]()
Do not selfscan with MRT, it just mess up with rom and SA modules, then selfscan stops.
Rewrite original rom, use LDR and rewrite original modules.
MRT has a lot of bugs for data recovery, but for selfscan is completely shit!
For selfscan drives use other tools, even WDMarvel is better than mrt.
P.S.
Also WD Marvel has bugs and i've seen interruptions while selfscanning also with that tool.
I just tried them few times for couriosity, i don't care about repairing hard drives so i haven't try to selfscan any drive since last 4/5 years.
The only tool that really worked for me was Sediv.
fzabkar wrote:Can you upload the original ROM and SA resources?
Does your drive spin up with the new ROM?
fzabkar wrote:The structure of your new ROM looks OK. PUIS is not enabled. I don't know what is wrong with it.
Edit:
The ROM in your resource dump is identical to the first ROM you posted.
fzabkar wrote:PUIS = Power Up In Standby
Could we see the ROM that TREX produced?
ID Size (bytes) Address Checksum
dir hdr dir hdr
0001 N/A 00004000 N/A 00082345 N/A
000A OK 0000004E 00000200 000FF000 00000000 OK
000B OK 0000013B 00000200 000FFEB6 00000000 OK
020B OK 0000013B 00000200 000FEEB6 00000000 OK
0181 OK 00000BA0 00000C00 000FD400 00000000 OK
0030 OK 00000400 OK 000FD000 00000000 OK
0047 OK 00000800 OK 000FF6B6 00000000 OK
000D OK 00000108 00000200 000FF04E 00000000 OK
0303 OK 00000060 00000200 000FF156 00000000 OK
004F OK 00000500 00000600 000FF1B6 00000000 OK ID Size (bytes) Address Checksum
dir hdr dir hdr
0001 N/A 00004000 N/A 00000000 N/A
000B OK 00000129 00000200 000FFCE2 00000000 OK
020B OK 00000129 00000200 000FECE2 00000000 OK
0030 FFFF 00000400 01FFFE00 000FD000 FFFFFF00 BAD
0047 FFFF 00000800 01FFFE00 000FF4E2 FFFFFE00 BAD
000D OK 00000094 00000200 000FF04E 00000000 OK
004F OK 00000400 OK 000FF0E2 00000000 OK
