| How to connect the hard drive terminal USB-3 WD10JDRW-11C7VS http://forum.hddguru.com/viewtopic.php?f=11&t=46450 |
Page 1 of 1 |
| Author: | hvd [ November 28th, 2026, 14:20 ] |
| Post subject: | How to connect the hard drive terminal USB-3 WD10JDRW-11C7VS |
Hello, I have a WD USB-3 WD10JDRW-11C7VS0 with PCB 810082 hard drive from 2026. How can I connect it via Terminal to reprogram the BIOS ? I have already removed four capacitors: C112 and C114, and then soldered a Chinese PCB board to unlock the ROM and convert it to SATA (see photos). The drive is detected in SATA mode and in SATA backup, but I cannot read the ROM using the Boot ROM (Com port) option. Attachment: Attachment: Attachment: I consulted the WD manual: it indicates connecting the RX, TX, and GND pins. I made this connection, but I still cannot read the ROM using the Boot ROM (Com port) option. Thank |
| Author: | fzabkar [ November 28th, 2026, 15:17 ] |
| Post subject: | Re: How to connect the hard drive terminal USB-3 WD10JDRW-11 |
Maybe you need this? https://www.hddoracle.com/viewtopic.php?p=17079#p17079 Your adaptor appears to be a 3.3V type, whereas the HDD PCB would be operating at 1.8V LVTTL levels. |
| Author: | pepe [ November 28th, 2026, 15:31 ] |
the old methods to access rom thru serport do not work on the locked MCUs. You need to use a programmer device to read/write flash on these. Once the pcb has an unlocked rom flashed, ROM is accessible thru VSC. pepe |
