 Post subject: Tips & tricks
PostPosted: June 26th, 2007, 18:35
tip 1. [PC-3000 ISA, Data Extractor - faster analysis] Logical scan is very slow due to ISA bus, if drive doesnt have problems with reading its possible to do some trick:
Start new task with copy to secondary master (same size will be good idea). Close task. Edit by any hexeditor file map.bin (replace 2E with B0) that DE will read "copied" sectors from clone. Open task again, then change disks. Now you can open explorer mode and make logical analysis at full speed of ata1 port.
note: make some practice first, otherwise you can easily overwrite analysed drive. ata-100 is much faster instead of pc3k isa port so maybe you will like this method.
 Post subject:
PostPosted: June 27th, 2007, 8:37
Good tip, Aviko.
Good to see you back.
Dobre
 Post subject:
PostPosted: June 28th, 2007, 10:24
very clever, thanks
 Post subject:
PostPosted: June 29th, 2007, 4:32
hi aviko
thanks advance
its very useful
wawalab :wink:
 Post subject:
PostPosted: July 14th, 2007, 4:58
Yeah right....!!! Why I haven't think about it ?? Thanks aviko !!! :D
