| maxtor n40p http://forum.hddguru.com/viewtopic.php?f=11&t=7348 |
Page 1 of 1 |
| Author: | HDDTECH [ July 2nd, 2007, 17:19 ] |
| Post subject: | maxtor n40p |
GOT 6E040L0 DRIVE WITH TYPICAL PROB... IT REPORTS 6E040L1 AND FIRWARE CODE NAR INSTEAD NAR OTHER MODULES OK HOW TO GET RID OF THESE PROBLEM ANY HELP WILL BE APPRECIATED |
| Author: | wawalab [ July 3rd, 2007, 0:20 ] |
| Post subject: | |
hi HDDTECH: whats your means for "FIRWARE CODE NAR INSTEAD NAR "??? |
| Author: | HDDTECH [ July 3rd, 2007, 9:46 ] |
| Post subject: | |
i mean NCR instead of NAR ....... |
| Author: | rameez [ July 3rd, 2007, 13:12 ] |
| Post subject: | |
PM me i have solution to this probelm . |
| Author: | wawalab [ July 3rd, 2007, 15:30 ] |
| Post subject: | |
into ALT SA. |
| Author: | RJARRRPCGP [ July 11th, 2007, 21:21 ] |
| Post subject: | Re: maxtor n40p |
HDDTECH wrote: GOT 6E040L0 DRIVE WITH TYPICAL PROB... IT
What typical problem is that? I have one for the PC I'm at right now. |
| Author: | mulan [ July 23rd, 2007, 10:46 ] |
try self scan if the drive have altsa (this is the only succesfully method that i know) |
| Author: | arfaizy13 [ July 25th, 2007, 14:47 ] |
u put hdd in safe mode and load ldr then it will become 6e040l0 then u chk modules, i have solved this type of problems in some hdds of 6e040l0, i got this type of prb when i wrote datacopy1.smb to drive, then its p-list was damaged, then i corrected this u also chk, it may solve ur problem |
| Author: | rameez [ July 26th, 2007, 12:09 ] |
the problem is in plist rewrite in safe mode with appropriate loader with RAM loaded . |
| Author: | arfaizy13 [ July 26th, 2007, 15:34 ] |
ya, correct solution, u find the correct ram and ldr for this hdd, first u put hdd in safe mode, load ldr. if plist is damaged then u write RAM and write plist, i hope the problem is solved now. |
