 Post subject: Slimline MAxtor SA defects
PostPosted: August 15th, 2007, 10:36
Recently I have been having some trouble repairing some N40P and Ares slimline maxtors. I am able to load a LDR and access the firmware and find the damaged firmware modules, and have donor firmware to write but on trying to write i get UNC and INF errors and am unable to repair the data. I know there is a way to re-assign SA defects but I am not exactly sure how. I am using PCI PC3000.
 Post subject: Re: Slimline MAxtor SA defects
PostPosted: August 15th, 2007, 13:24
I think hotswap is here advisable.
Dobre
Murphy was an optimist
PostPosted: August 15th, 2007, 22:44
Did you try to run Surface verification?
PostPosted: September 13th, 2007, 6:07
load a right LDR
check SA surface
write testting must pass
then rewrite damaged modules
if all succeed then test show bad still surface of SA then you need change UBA local address because its "real damaged" sometimes "re-assign SA defects " not use.
:x
PostPosted: September 13th, 2007, 7:20
wawalab wrote:
l
:x
To change UBA local address, how to do this ?
My Forum
PostPosted: October 10th, 2007, 11:20
selfscan from alternate SA
Users browsing this forum: No registered users and 90 guests
