| Slimline MAxtor SA defects http://forum.hddguru.com/viewtopic.php?f=11&t=7571 |
Page 1 of 1 |
| Author: | tiktaq [ August 15th, 2007, 10:36 ] |
| Post subject: | Slimline MAxtor SA defects |
Recently I have been having some trouble repairing some N40P and Ares slimline maxtors. I am able to load a LDR and access the firmware and find the damaged firmware modules, and have donor firmware to write but on trying to write i get UNC and INF errors and am unable to repair the data. I know there is a way to re-assign SA defects but I am not exactly sure how. I am using PCI PC3000. Thanks |
| Author: | dobrevjetser [ August 15th, 2007, 13:24 ] |
| Post subject: | Re: Slimline MAxtor SA defects |
I think hotswap is here advisable. Dobre |
| Author: | Starling [ August 15th, 2007, 22:44 ] |
Did you try to run Surface verification? |
| Author: | wawalab [ September 13th, 2007, 6:07 ] |
load a right LDR check SA surface write testting must pass then rewrite damaged modules if all succeed then test show bad still surface of SA then you need change UBA local address because its "real damaged" sometimes "re-assign SA defects " not use. |
| Author: | cryoborgofthevenus [ September 13th, 2007, 7:20 ] |
wawalab wrote: l if all succeed then test show bad still surface of SA then you need change UBA local address because its "real damaged" sometimes "re-assign SA defects " not use. To change UBA local address, how to do this ? |
| Author: | valy1965 [ October 10th, 2007, 11:20 ] |
selfscan from alternate SA |
