Maxtor 4D080H4
http://forum.hddguru.com/viewtopic.php?f=11&t=7599
Author:  HDDTECH [ August 21st, 2007, 16:37 ]
Post subject:  Maxtor 4D080H4
This drive spins and seek ok , but it keep in busy mode. i did hot swap, no good, i try to read in safe mode same thing.... how to fix any heip will be appreciated.
Author:  rameez [ August 22nd, 2007, 10:24 ]
Post subject:  Re: Maxtor 4D080H4
Head parks or not .
Author:  pcimage [ August 25th, 2007, 5:31 ]
I got the same thing with a Samsung HD160JJ, sounds OK but never becomes ready. Even with Hot Swap! :shock:
Author:  cryoborgofthevenus [ August 27th, 2007, 6:39 ]
What about initializing from internal SA using ISA version ?
Author:  Starling [ August 29th, 2007, 13:35 ]
safe mode->loader->check SA.
Author:  rameez [ August 30th, 2007, 13:45 ]
Initialization from SA is also option of PCI .
Author:  wawalab [ September 5th, 2007, 10:50 ]
replace PCB try it again :)
Author:  arfaizy13 [ September 8th, 2007, 1:41 ]
if hdd does not park then its fw problem.
if hdd parks, then mostly its card prb
