 Post subject: Safemode WD Sata
PostPosted: August 22nd, 2007, 2:12
Hi guy's,
Is there anyone that knows the right jumper settings to safe mode for a WD1600JD Sata?
The original manual don't say nothing of this.
I've tryed to jumper all 4, but no luck...can't get it into kernel.
Bosse
http://www.rescue-it.se
 Post subject: Re: Safemode WD Sata
PostPosted: August 22nd, 2007, 4:15
mr_spokk wrote:
Hi guy's,
Bosse
The setting is sorted now ;-)
Bosse
PostPosted: August 28th, 2007, 17:19
Then share it with the public .
PostPosted: September 5th, 2007, 6:25
Hi Amarbir,
As it turned out that it didn't work for me eventually, might be a bad pcb or wrong instuctions.
So as I didn't know for sure and got a successful reading I did not post the solution.
There is no point to tell a solution if it's wrong...or is it? ;-)
But as far as I know and heard, the pcb should be off, and no jumpers on....
Please let me know if anyone got this to work.
Cheers
Bosse
PostPosted: September 5th, 2007, 11:16
I think its problem with PCB because i use 4 jumper to get kernel mode.
DF
DF :)
www.datatracksystem.net
PostPosted: September 7th, 2007, 7:52
darkforce1 wrote:
I think its problem with PCB because i use 4 jumper to get kernel mode...
:arrow: darkforce1
If drive is WDC Caviar Cyl32 SATA U can not use 4 jumper to get kernel mode...
Mikippp
PostPosted: September 8th, 2007, 14:39
Thank you Mikippp
for updating me. I have always worked with Marvel so not knowing SM for cavier
Thank you once again
DF :)
DF :)
PostPosted: September 10th, 2007, 3:36
Little rectification...
My previous statement was not precise...
If drive is *WDC Caviar Cyl32 SATA U can use 4 jumper to get PSV Mode..., but **PC-3000 PCI / PC-3000 UDMA not work with such drive in kernel mode...
* Tested on WD1600JD-40GBB2 (Polaris)
** PC-3000 PCI (2.27) / PC-3000 UDMA (3.01)
Mikippp
PostPosted: September 13th, 2007, 0:07
Hi Mikippp
Again thank you for correction
DF
DF :)
