| Safemode WD Sata http://forum.hddguru.com/viewtopic.php?f=11&t=7601 |
Page 1 of 1 |
| Author: | mr_spokk [ August 22nd, 2007, 2:12 ] |
| Post subject: | Safemode WD Sata |
Hi guy's, Is there anyone that knows the right jumper settings to safe mode for a WD1600JD Sata? The original manual don't say nothing of this. I've tryed to jumper all 4, but no luck...can't get it into kernel. Regards Bosse |
| Author: | mr_spokk [ August 22nd, 2007, 4:15 ] |
| Post subject: | Re: Safemode WD Sata |
mr_spokk wrote: Hi guy's, Is there anyone that knows the right jumper settings to safe mode for a WD1600JD Sata? The original manual don't say nothing of this. I've tryed to jumper all 4, but no luck...can't get it into kernel. Regards Bosse The setting is sorted now Bosse |
| Author: | Amarbir[CDR-Labs] [ August 28th, 2007, 17:19 ] |
Hi, Then share it with the public . |
| Author: | mr_spokk [ September 5th, 2007, 6:25 ] |
Amarbir wrote: Hi, Then share it with the public . Hi Amarbir, As it turned out that it didn't work for me eventually, might be a bad pcb or wrong instuctions. So as I didn't know for sure and got a successful reading I did not post the solution. There is no point to tell a solution if it's wrong...or is it? But as far as I know and heard, the pcb should be off, and no jumpers on.... Please let me know if anyone got this to work. Cheers Bosse |
| Author: | darkforce1 [ September 5th, 2007, 11:16 ] |
I think its problem with PCB because i use 4 jumper to get kernel mode. DF |
| Author: | Mikippp [ September 7th, 2007, 7:52 ] |
darkforce1 wrote: I think its problem with PCB because i use 4 jumper to get kernel mode... Hi, If drive is WDC Caviar Cyl32 SATA U can not use 4 jumper to get kernel mode... Mikippp |
| Author: | darkforce1 [ September 8th, 2007, 14:39 ] |
Thank you Mikippp for updating me. I have always worked with Marvel so not knowing SM for cavier Thank you once again DF |
| Author: | Mikippp [ September 10th, 2007, 3:36 ] |
Hi, Little rectification... My previous statement was not precise... If drive is *WDC Caviar Cyl32 SATA U can use 4 jumper to get PSV Mode..., but **PC-3000 PCI / PC-3000 UDMA not work with such drive in kernel mode... * Tested on WD1600JD-40GBB2 (Polaris) ** PC-3000 PCI (2.27) / PC-3000 UDMA (3.01) Mikippp |
| Author: | darkforce1 [ September 13th, 2007, 0:07 ] |
Hi Mikippp Again thank you for correction DF |
