| Maxtor Firmware Problem - Any suggestions? http://forum.hddguru.com/viewtopic.php?f=11&t=7621 |
Page 1 of 1 |
| Author: | zed [ August 27th, 2007, 2:53 ] |
| Post subject: | Maxtor Firmware Problem - Any suggestions? |
Hi All, I have a Maxtor hard disk with a firmware problem. It's detected in BIOS as Maxtor CALYPSO. The disk sounds normal and does not make any unusual sounds. I am using PC-3000 PCI for Windows With Data Extractor. Scanning the module table it appears 2 modules are unreadable. 1 of these is critical to restore the drive to be able to recover the data (this is my goal). I believe the disk may have a bad sector or problem reading for this module. I have run the option in PC-3000 called 'SA Surface Verification' and have ticked 'reassign bad sectors by writing' but this has not helped. The results are below as well as a screenshot attached. Any suggestions on what else to try? Thanks in advance for any assistance. Zed Attachment: ========================================= Applying SRV SA writing test Data writing Data reading Writing test finalized with error. Recovery is imposible. SA surface verification Zone Id ................................... 0 Start UBA ............................ 8 Size ................................. 1 500 8 ......................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89717/3/8 759 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/375 760 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/375 761 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89718/3/375 Errors .................................... 4 Zone Id ................................... 1 Start UBA ............................ 1 508 Size ................................. 4 416 Errors .................................... 0 Zone Id ................................... 2 Start UBA ............................ 8 022 Size ................................. 4 800 Errors .................................... 0 Zone Id ................................... 3 Start UBA ............................ 12 822 Size ................................. 2 600 Errors .................................... 0 Zone Id ................................... 4 Start UBA ............................ 15 422 Size ................................. 400 Errors .................................... 0 Zone Id ................................... 5 Start UBA ............................ 5 924 Size ................................. 2 098 Errors .................................... 0 Zone Id ................................... 6 Start UBA ............................ 15 936 Size ................................. 1 500 15 936 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89758/3/192 16 682 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89760/3/170 16 683 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89760/3/170 Errors .................................... 3 Zone Id ................................... 7 Start UBA ............................ 17 436 Size ................................. 4 416 Errors .................................... 0 Zone Id ................................... 8 Start UBA ............................ 0 Size ................................. 8 8 ......................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 89717/3/8 Errors .................................... 1 Zone Id ................................... 9 Start UBA ............................ 44 904 Size ................................. 8 Errors .................................... 0 Test completed |
| Author: | cryoborgofthevenus [ August 27th, 2007, 6:49 ] |
| Post subject: | Re: Maxtor Firmware Problem - Any suggestions? |
Hi ! normal capacity still undetected ? head map problem I think...Rewrite module #1F. Read again all modules and write back to SA. I usually solve this problem using ISA. I don't know about PCI... |
| Author: | Starling [ August 29th, 2007, 19:05 ] |
Hot swap. |
| Author: | pcimage [ August 29th, 2007, 19:16 ] |
Smart Hot Swap better? |
| Author: | cryoborgofthevenus [ August 30th, 2007, 2:07 ] |
I don't know about Starling idea (HOT SWAP)....but it's probably better be done in PCI....which I don't have one.... As far as I can understand, UBA 8 error means in ISA this model will be detected in safe mode as Cyl -1 Head 8 and so on (this is module #1F damaged). SA write test usually failed. |
| Author: | valy1965 [ August 30th, 2007, 3:43 ] |
Try another loader because ROM loader is different to ROM SA. You must try HDD ID reading and if you only see a correct serial you can try start program. Of course the hdd must you have it in safe mode? No try star utilitar program if you don't see correct serial because adaptive reading-writing are false. |
| Author: | inworld [ August 30th, 2007, 10:40 ] |
Do you Try to start the drive whit correct LDR for that Drive?. |
| Author: | valy1965 [ August 30th, 2007, 11:00 ] |
In menu you have "create LDR" and after this star program with this corect loader. |
| Author: | pc3k [ November 14th, 2007, 11:49 ] |
hi help me i use pc3k in win but idont read and write rom ? and i repair hdd maxtor 40gb n40p i up firmware but rom cs ? |
| Author: | coolmac [ November 29th, 2007, 4:48 ] |
hi;zed IF is critical for the Hd recovery to get data back as far as i say: 1 try to get a healthy identical one from the drive which has same mode, same capacity,same checksum,and overwrite then. 2 check the SA copy by running the other sa head and got a good 1F and overwrite .look,we may say the head you current operating is main one,and other heads working with the main one are secondary ,but they may have a sa copy too. |
| Author: | valy1965 [ November 29th, 2007, 19:13 ] |
1. Put the hdd in safe-mode 2. Star with loader YCRXXXXX in alternate SA 3. Save modules and loader 4. No need data..., Run->Selfscan |
