 Post subject: seagate problem
PostPosted: August 27th, 2007, 11:19
hi
i have a seagate drive baracuda ata IV st340016a that is not detected
i connected the drive to pc3k pci and the drive starts spinning (with knocking sound) and in terminal i get
head mask 0000 head mask 0000 head mask 0000 head mask 0000...............
for 10 times or more and after that the drive stops the spindle
the drive is always at age 60 (if i change the drive to age 50 after power down/up the drive is again at age 60)
can anyone tell me if it is a head problem?
i need the data from the drive
thanks in advance
 Post subject: Re: seagate problem
PostPosted: August 28th, 2007, 1:11
Hi mulan ! Can you check wheteher the ROM is properly detected by your PC 3000 ? If not, than it's head problem CMIIW..
My Forum
PostPosted: August 28th, 2007, 3:51
the terminal looks like:
Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - SNOWMASS - 1_Disk 3.75 11-20-01 13:27
Built for SNOWMASS,SaratogaII,NAPA,TI1761 PreAmp,VTC5833 PreAmp,InternalSpin,SVC125,OneToOne,2Disk,LowDelta,196 Servos,7200RPM,8Pole,NonModGray,90MHz,Code DRAM,Early Exit,RwFeat=0004
Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - HPPHSNOWMASS - 1_Disk 3.75 11-20-01 13:27
Spin Up Time Out Failure!
Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - AutoRd Err 11 at 7009.00.0000
Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - INVALID Cert Disk Code - ROM Resident Revision Required: 3.75
Command Inactive - No VALID Cert Code Detected
T>
T>M
Using Fallback defaults for 64K by 16 Flash
Flash: Device Code = 20 , Manufacturer = 98 , ASW = ffff , Fallback ASW = 8002
Press any key to continue.
Preamp ID is: 00
Interface task reset
1024k x 16 buffer detected
Power Cycling
ATReset
Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 -
T>Head Mask 0000 - Head Mask 0000 -
i think the head is dead. any other opinion?
PostPosted: August 28th, 2007, 9:08
nobody? knows
PostPosted: August 28th, 2007, 10:35
Have you tried to change pcb and check terminal report again to see if result is the same ?
PostPosted: August 28th, 2007, 11:03
yes. the result is the same
PostPosted: August 28th, 2007, 11:09
So replace heads.
PostPosted: August 29th, 2007, 5:37
my guess is the same. thank you all
PostPosted: August 29th, 2007, 10:39
If u get
T> then u can try to check heads to determine if its head problem or no
Best Regards
Sinceraly
Alberto Pavón
IT & Data Services
PostPosted: August 3rd, 2008, 11:36
mulan wrote:
hi
thanks in advance
edit rom,kill the 0 head
