| seagate problem http://forum.hddguru.com/viewtopic.php?f=11&t=7624 |
Page 1 of 1 |
| Author: | mulan [ August 27th, 2007, 11:19 ] |
| Post subject: | seagate problem |
hi i have a seagate drive baracuda ata IV st340016a that is not detected i connected the drive to pc3k pci and the drive starts spinning (with knocking sound) and in terminal i get head mask 0000 head mask 0000 head mask 0000 head mask 0000............... for 10 times or more and after that the drive stops the spindle the drive is always at age 60 (if i change the drive to age 50 after power down/up the drive is again at age 60) can anyone tell me if it is a head problem? i need the data from the drive thanks in advance |
| Author: | cryoborgofthevenus [ August 28th, 2007, 1:11 ] |
| Post subject: | Re: seagate problem |
Hi mulan ! Can you check wheteher the ROM is properly detected by your PC 3000 ? If not, than it's head problem CMIIW.. |
| Author: | mulan [ August 28th, 2007, 3:51 ] |
the terminal looks like: Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - SNOWMASS - 1_Disk 3.75 11-20-01 13:27 Built for SNOWMASS,SaratogaII,NAPA,TI1761 PreAmp,VTC5833 PreAmp,InternalSpin,SVC125,OneToOne,2Disk,LowDelta,196 Servos,7200RPM,8Pole,NonModGray,90MHz,Code DRAM,Early Exit,RwFeat=0004 Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - HPPHSNOWMASS - 1_Disk 3.75 11-20-01 13:27 Built for SNOWMASS,SaratogaII,NAPA,TI1761 PreAmp,VTC5833 PreAmp,InternalSpin,SVC125,OneToOne,2Disk,LowDelta,196 Servos,7200RPM,8Pole,NonModGray,90MHz,Code DRAM,Early Exit,RwFeat=0004 Spin Up Time Out Failure! Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - AutoRd Err 11 at 7009.00.0000 Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - AutoRd Err 11 at 7009.00.0000 Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - INVALID Cert Disk Code - ROM Resident Revision Required: 3.75 Command Inactive - No VALID Cert Code Detected T> T>M Using Fallback defaults for 64K by 16 Flash Flash: Device Code = 20 , Manufacturer = 98 , ASW = ffff , Fallback ASW = 8002 Press any key to continue. Preamp ID is: 00 Interface task reset 1024k x 16 buffer detected SNOWMASS - 1_Disk 3.75 11-20-01 13:27 Power Cycling ATReset Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - Head Mask 0000 - T>Head Mask 0000 - Head Mask 0000 - i think the head is dead. any other opinion? |
| Author: | mulan [ August 28th, 2007, 9:08 ] |
nobody? knows |
| Author: | dmarques [ August 28th, 2007, 10:35 ] |
Have you tried to change pcb and check terminal report again to see if result is the same ? |
| Author: | mulan [ August 28th, 2007, 11:03 ] |
yes. the result is the same |
| Author: | dmarques [ August 28th, 2007, 11:09 ] |
So replace heads. |
| Author: | mulan [ August 29th, 2007, 5:37 ] |
my guess is the same. thank you all |
| Author: | beto [ August 29th, 2007, 10:39 ] |
If u get T> then u can try to check heads to determine if its head problem or no Best Regards Sinceraly Alberto Pavón IT & Data Services |
| Author: | suntom [ August 3rd, 2008, 11:36 ] |
mulan wrote: hi i have a seagate drive baracuda ata IV st340016a that is not detected i connected the drive to pc3k pci and the drive starts spinning (with knocking sound) and in terminal i get head mask 0000 head mask 0000 head mask 0000 head mask 0000............... for 10 times or more and after that the drive stops the spindle the drive is always at age 60 (if i change the drive to age 50 after power down/up the drive is again at age 60) can anyone tell me if it is a head problem? i need the data from the drive thanks in advance edit rom,kill the 0 head |
