HDD GURU FORUMS
http://forum.hddguru.com/
NEED ROM FOR WD2500JD-00HBC0
http://forum.hddguru.com/viewtopic.php?f=11&t=7890
Page 1 of 1
Author:  Maestro [ October 16th, 2007, 8:34 ]
Post subject:  NEED ROM FOR WD2500JD-00HBC0
Hi everyone,
Does anyone have ROM for the following drive?
MDL WD2500JD-00HBC0
FIRM 08.02D08
ROM VERSION 21.DCJ
I need it as soon as possible so any help would be really appreciated.
Thanks in advance
Maestro
hard_disk_maestro@hotmail.com
Author:  dobrevjetser [ October 16th, 2007, 8:40 ]
Post subject:  Re: NEED ROM FOR WD2500JD-00HBC0
Hi Maestro,
I have version 21.02J
Do you want to try it ?
Do you have UDMA? Export is only for this version.
Regards,
Dobre
Author:  Maestro [ October 16th, 2007, 9:02 ]
Hi Dobre,
Yes i am using UDMA version so if you can send it to give it a try?
Thanx
Maestro
Author:  uto [ October 22nd, 2010, 5:47 ]
Hi to all! Does anyone STILL have the rom for that drive? I've got the same problem of maestro, and I have, of course, the UDMA version, thank a lot, bye
Author:  pcimage [ October 22nd, 2010, 14:01 ]
Here you are...
Rom.rar [123.09 KiB]
Downloaded 426 times
Info.txt [974 Bytes]
Downloaded 636 times
Author:  cheadledatarecovery [ October 22nd, 2010, 18:58 ]
PM me if you want a full copy of ROM & Firmware,
best wishes,
John
http://www.phpbb.com/
