 Post subject: Normal PC3000 utilities
PostPosted: October 23rd, 2007, 0:28
Dear all HDDgurus,
I am beginner of PC3000. I have used it 3 months ago so I do not have much understand of it.
I checked and found in PC3000 manual and on its website, but there is not information about these utilities in PC3000. Could you explain clearly, what are their functions and can we use them to diagnose HD malfunctions?
1) Cyclic status register reading ?
2) Cyclic NOP sending
3) Bus test
4) Sector buffer test
5) Cyclic sector writing
6) Cyclic sector reading
7) IRQ test
8) Explorer profile folder
9) Utility profile management
10) Defect list edit
11) Terminal
12) Script.
And it take me a long time to check the 1 and 2 functions althought my HD has only 30Gb
Thanks for yr help.
 Post subject: Re: Normal PC3000 utilities
PostPosted: October 26th, 2007, 21:40
Noone answer me hic hic.
I am still waiting for your replies.
Thanks a lot.
Thanks a lot.
PostPosted: October 29th, 2007, 15:38
Then you can go ahead and try and ask Acelab about these? :D
Dmitry
PostPosted: October 30th, 2007, 2:54
I don't think anyone is going to want to invest dozens of hours in a suitable response when they themselves probably spent hundreds of hours working it out.
All respect, of course - but you need to work through those questions under your own steam - just as we all did.
Duncan
PostPosted: October 30th, 2007, 5:30
I'm totally agree with @maysoft and @Odiferous
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: October 31st, 2007, 0:26
I tried myselt to find information but no result.
I thought that they are normal utilities of PC3000 so the ACE must explain them in user
manual. This problem indicates that the ACE support customers not well.
And I work P3000 alone so it is difficult to solve out.
Could you give me a hint.
PostPosted: October 31st, 2007, 10:06
3) Bus test
7) IRQ test
This answers u get understanding the HDD Engineering and Digital System´s u can try to search it and learn some about then make your test´s with dummy´s hDD and learn about HDD´s Engineering field take a long of time
Alberto
