| HITACHI, HTS424040M9AT00 password removal http://forum.hddguru.com/viewtopic.php?f=11&t=7995 |
Page 1 of 1 |
| Author: | pninja [ November 6th, 2007, 2:29 ] |
| Post subject: | HITACHI, HTS424040M9AT00 password removal |
Hi Guys, Do you have any idea how can I remove ATA password from a HITACHI HTS424040M9AT00. I have PC3K, ISA and PCI versions but either supports this model for password removal. I appreciate Any hint or advise. |
| Author: | Starling [ November 7th, 2007, 15:44 ] |
| Post subject: | Re: HITACHI, HTS424040M9AT00 password removal |
PC3000 PCI 2.27 has this model in the list. To unlock you have to disconnect PCB from HDA, set safe mode, read NVRAM, change byte 9 to 0x00, write NVRAM back. Then connect PCB back to drive, enter the utility and rewrite module ISEC. After that write back original NVRAM and that's it. |
| Author: | pninja [ November 8th, 2007, 10:49 ] |
Starling wrote: PC3000 PCI 2.27 has this model in the list. To unlock you have to disconnect PCB from HDA, set safe mode, read NVRAM, change byte 9 to 0x00, write NVRAM back. Then connect PCB back to drive, enter the utility and rewrite module ISEC. After that write back original NVRAM and that's it. Hi Starling, Thanks a lot for the reply the result. regards |
| Author: | pninja [ November 9th, 2007, 2:09 ] |
Hi Starling, Thank you very much for the procedure. You have mentioned that I have to write back the module ISEC, I did not find such module in the modules list. Did you mean module ICES? If you have this module in your data base may I have a copy? I do not have donor drive in the stock right now. I already have changed the byte 9 of NV-RAM from 01 to 00 and wrote back to the PCB in safe mode. regards Pninja |
| Author: | Starling [ November 12th, 2007, 13:11 ] |
You can read original clean ICES module from Factory copy and write it to Copy0. |
