Discussions related to PC-3000
Please no pirated software here!
Strange behaviour of SP8004H
November 8th, 2007, 7:13
Hi Friends,
Strange case with a samsung SP8004H
The drive came in with the SA badly damaged. Using composite reading, i could read all modules.
Writing the SA was not possible.
So i got an identical drive and made a hotswap.
I used DE to make a data-copy.
Strange thing is: All sectors that are read as good are empty, and the sectors read without CRC control contain valid data :?
I changed heads and could rewrite the SA modules, some are still damaged but not the critical ones. Still same problem. No data
I also tried to read the entire disk without CRC, but that is not giving good result.
Anybody a suggestion?
Thanks in advance,
Dobre
Re: Strange behaviour of SP8004H
November 12th, 2007, 0:30
Hello dobrevjester
when u read the sectors did u get some error´s UNC; IDNF; ABRT ?
Best Regards
November 12th, 2007, 5:08
Hi Alberto,
Most errors are UNC but sometimes it is also AMN.
Dobre
