| Strange behaviour of SP8004H http://forum.hddguru.com/viewtopic.php?f=11&t=8004 |
Page 1 of 1 |
| Author: | dobrevjetser [ November 8th, 2007, 7:13 ] |
| Post subject: | Strange behaviour of SP8004H |
Hi Friends, Strange case with a samsung SP8004H The drive came in with the SA badly damaged. Using composite reading, i could read all modules. Writing the SA was not possible. So i got an identical drive and made a hotswap. I used DE to make a data-copy. Strange thing is: All sectors that are read as good are empty, and the sectors read without CRC control contain valid data I changed heads and could rewrite the SA modules, some are still damaged but not the critical ones. Still same problem. No data I also tried to read the entire disk without CRC, but that is not giving good result. Anybody a suggestion? Thanks in advance, Dobre |
| Author: | beto [ November 12th, 2007, 0:30 ] |
| Post subject: | Re: Strange behaviour of SP8004H |
Hello dobrevjester when u read the sectors did u get some error“s UNC; IDNF; ABRT ? Best Regards |
| Author: | dobrevjetser [ November 12th, 2007, 5:08 ] |
Hi Alberto, Most errors are UNC but sometimes it is also AMN. Dobre |
