Page 1 of 1
Hot Swap
Posted: November 21st, 2007, 3:49
by saniosoft
hi fellows.
i am a newbise. tell me any body about hot swap prosedure of maxtor hard drive
thanks
Re: Hot Swap
Posted: November 21st, 2007, 19:39
by pcimage
First of all
Why would u need to do hot swap?
Some history would help.
Re: Hot Swap
Posted: November 23rd, 2007, 3:40
by saniosoft
Hi pcimage!
extually i have a wd hard drive WD400BB - 75CLB0 and i have need data. when i give only give it up power hard drive did not spin at all. its motor ic is damage. i want to replace its pcb. please give me some information how i change the pcb. because when i change the pcb and give the power hard is cliking noise.
Re: Hot Swap
Posted: November 29th, 2007, 4:16
by coolmac
hi,guy
easy!
solder the born motor IC(please pay more attention to the parameter printed,should be special for WD brand) from the bad PCB and get a identical good one insteaded.if you not sure you can do it on you own,ask somebody who can to help you,just pay a little meony after that .
Re: Hot Swap
Posted: December 12th, 2007, 14:46
by rameez
After changing the pcb u also need to solder orignal ROM on the new pcb .
