Page 1 of 1
Hitachi HDS722580VLAT20, MAC firmware (V32KA60A), NV-RAM nee
Posted: January 18th, 2008, 8:42
by yco
Hello everybody.
I got a Mac HDD which is unreadable. PC3K cannot detect Drive ID. Someone else was working on this HDD, I am not even sure if the controller is original.
Checked SA and found few errors, rewrote from copies but there is some strange thing:
In "Utility Status" it shows
NV-RAM ID: V32KA60Á
USAG version: V32KA60A
Report on module USAG, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Loaded.................................. : Yes
Identified.............................. : Yes
mu-code................................. : V32KA60A
FW Ver code............................. : 8A629828
Incompatible with NV-RAM!
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200A1
Firmware................................ : V32KA60A
Model................................... : Hitachi HDS722580VLAT20
Serial.................................. : VNR26FC2C5RLBM
Could anybode send me a correct NV-RAM please? I believe this is the problem
Thanks in advance, Pawel.
Re: Hitachi HDS722580VLAT20, MAC firmware (V32KA60A), NV-RAM nee
Posted: January 18th, 2008, 8:47
by dobrevjetser
Hi Pawel,
It seems that your drive uses the alternate SA.
You should start the utility and then choose 'Switch SA access' to put the NVRam in its original state.
Then repower your drive and start the utility.
Now it should show the correct NVRAM ID.
Regards,
Dobre
Posted: January 19th, 2008, 9:05
by yco
Hi Dobre!
I don't know why it wouldn't work previously when I tried but it did this time.
Best regards and big thanks.
Pawel
